Saturday, Jun 05, 2010 at 21:18
So are you using the words "while travelling" to mean when stationary ??
I would not use the terminology "only practical way to power the fridge on 240V while travelling would be to have"
I would have stated "only practical way to power the fridge on 240V while
CAMPING would be to have"
However, I do still have concerns about having the 240 Volt inverter and battery situated in the vehicle away from the fridge situated in the caravan, even when stationary.
Reason is because the 240 volt cable has to run out in the open between 2 vehicles (car and caravan) as you have posted 'a 600 Watt inverter is in the vehicle and run 240V across to the fridge in the caravan'
I can only believe the cable goes out from, and into the 'vehicles' via a window or door, so yes, I do believe it's dangerous.
As I've said, the inverter, battery and fridge should all be in same vehicle.
You would not be able to power the fridge on 240v when it's in the caravan and stationary at a
camp site, and you have gone for a drive in the vehicle, because the inverter and battery has obviously been taken away with the vehicle.
Lex,
Thank you :-)
Maîneÿ . . .
689889
