Monday, Jun 07, 2010 at 23:57
Hello Don,
longest run from battery to fridge, to keep voltage drop between controller and battery at a minimum.
So you're relying on the fridge low voltage cutout, and not on the one inside the controller?
Or does this controller have no load output?
BTW, the clock is ticking for your AGM battery if it's not receiving full charge by the end of the day.
To check for this, select a time in the afternoon when the insolation on the panel is still substantial, maybe around 3 or 4 pm. You want to see a voltage of at least 14.4 to 14.7V.
Chances are you won't for two reasons:
el cheapo controllers only regulate at a single voltage of around 13.8V.
Because you're subjecting the battery to a cyclic load pattern, it wants to get boost charged before the next discharge session (night time).
Second reason for slow walk down of battery charge (and capacity in the medium term) in this configuration, is the 80W panel only provides around 23Ah per day, if you're lucky.
But the fridge consumes slightly more than that as you discovered when you did your 3 day test (120Ah/3days=40Ah/day)
Best regards, Peter
690155
