Petrol tank pressure GQ Patrol
Submitted: Wednesday, Jun 16, 2010 at 08:09
gonebush SA
Hi, as you may be aware we have just had many hassles sorting out our leaking
fuel tank hoses and ended up getting the pipes that come off of the
tank and off of the filler professionally sleeved to make them take the standard
fuel line hose (38mm). anyway now it's all back together we put only a couple of litres of
fuel in the
tank to take it to get more
fuel (we also have LPG) and when opening the
fuel cap there is quite a considerable amount of pressure, (more than our commodore has). my question is, is that normal for these tanks to pressure up as it's always had a leak or 2 before so we have never noticed it? or is there a breather hose that may have a problem somewhere?
thanks from chris.
Reply By: Dave(NSW) - Wednesday, Jun 16, 2010 at 10:09
Chris,
It sounds like the breather hose is kinked or blocked, Though the more space in a petrol
tank the more the pressure can build up.
Cheers Dave..
421027
Reply By: Member - John and Val - Wednesday, Jun 16, 2010 at 11:09
Had a similar problem in our petrol Troopy. In our case vapour is vented through a charcoal filter that had blocked up somehow.
| J and V
- Albert Einstein
421033
Reply By: oldfart1953 - Wednesday, Jun 16, 2010 at 11:11
Is it pressure or vacuum?
421034
Follow Up By: gonebush SA - Wednesday, Jun 16, 2010 at 14:54
hi, yes it's definitely pressure, as soon as the cap is loosened slightly there is a real noise of pressure escaping, so for the time being and to be sure we have not fully tighten the cap until we can get time to drop the
tank AGAIN, thanks from Chris.
691301
Reply By: ian zzr - Wednesday, Jun 16, 2010 at 21:37
hi , i would be looking at your carbon canister and
fuel vent lines from the
tank to it , and then the line from the canister to the intake side of the engine, but if raw
fuel got that far it would leak out of the bottom of the canister, as they to have a drain for safety reasons
421117
