Dual Tank Change-Over Switch
Submitted: Friday, Jun 18, 2010 at 17:03
Member - Kevin F (QLD)
G,day.. I have a '94 Diesel Troopy & have been having some issues with rear
tank.. It is using
fuel when dashboard switch is off. Has anyone had this problem ? Would be happy to hear of any suggestions to fix this problem. Regards Kev.
Reply By: Member - Stuart P (WA) - Friday, Jun 18, 2010 at 23:31
you will need your gauge repaired . the contacts in the switch will be stuck(welded) together it is a reasonably common problem
421380
Follow Up By: heiratuus - Saturday, Jun 19, 2010 at 10:19
also check that the earth at the solenoid is good have had a broken wire underneath the vehicle
691758
Reply By: Member - sdr00y (Beecroft,NSW) - Monday, Jun 21, 2010 at 14:13
I don't really have a fix but rather a simple solution, cost free.
Fill both tanks, use the
fuel in the rear
tank first till it runs out, then swap over to the front
tank.
That is what I do with
mine. I hate using up the front
tank first because the
fuel light then stays on for the duration of the use of the rear
tank. If you use up the rear
tank first you should have no problems.
421643
