2010 Patrol 3.0TD manual GCM
Submitted: Saturday, Jun 19, 2010 at 12:35
ThreadID: 79472 Views:13596 Replies:5 FollowUps:5
Can anybody tell me the GCM for a 2010 Nissan Patrol 3.0TD? We will be pulling a van with GVM of 2750kg. I cannot find the Patrol's GCM anywhere.
Thanks,
Anthony
Reply By: Notso - Saturday, Jun 19, 2010 at 14:41
Check out the VIN plate on the bulkhead.
Some of them had it there on an aluminium plate popped to the bulkhead.
I think it was about 6250kgs or thereabouts. Haven't got mine any more so can't check.
AnswerID: 421422
Reply By: AntandNat - Saturday, Jun 19, 2010 at 15:35
THanks for that. the dealer has just confirmed the same. Did you tow with yours? If so, will the vehicle handle a 2.75tonne van well?
AnswerID: 421426
Follow Up By: Member - DAZA (QLD) - Saturday, Jun 19, 2010 at 15:55
Is it Manual or Auto?
*Auto is 2500kg
*Manual is 3000 kg
FollowupID: 691785
Follow Up By: Dave(NSW) - Saturday, Jun 19, 2010 at 15:56
Is the van 2.75t loaded for going away or empty?
GU RULES!!
FollowupID: 691787
Follow Up By: Member - DAZA (QLD) - Saturday, Jun 19, 2010 at 16:26
Yeh I stuffed up, Manual Towing Weight 3200kgs. Auto Towing Weight 2500kgs
FollowupID: 691790
Follow Up By: Notso - Saturday, Jun 19, 2010 at 16:57
Mine was an earlier model, towed a 2 tonne van. Kept it for 6 years and most of it's life was towing.
It was running as good as the day I bought it when I traded it in at 195000ks
FollowupID: 691791
Reply By: AntandNat - Saturday, Jun 19, 2010 at 17:08
It is a manual and the van is 2.75t loaded. I trust the Patrol will be up to the task.
AnswerID: 421434
Reply By: Ianw - Saturday, Jun 19, 2010 at 18:50
Kerb Weight (kg) 2512
Tare Mass (kg) 2512
Gross Combination Mass (kg) 6230
Gross Vehicle Mass (kg) 3060
Pay Load (kg) 548
Towing Braked (kg) 3200
Towing Not Braked (kg) 750
Wheel Base (mm) 2970
Length (mm) 5050
Width (mm) 1940
Height (mm) 1855
Track Front (mm) 1605
Track Rear (mm) 1625
From Redbook.com.au
Ian
AnswerID: 421446
Reply By: AntandNat - Saturday, Jun 19, 2010 at 19:24
Thank you for feedback. I will post the performance and hope it supports all of the positive comments rather than the negative.
AnswerID: 421450
Follow Up By: Member - Andrew (WA) - Saturday, Jun 19, 2010 at 23:39
I had a series III 3.0Tdi and thought it was a great car. I traded it for a 100series cruiser and it's good but the patrol was just as good. They both have their good and bad.
I towed around Oz with the Patrol and it was great. The only advise I offer is to try and park on level or downward slopes where possible. The clutch doesn't really like taking off up hill pulling over 2 ton.
Cheers.
FollowupID: 691861
