simpson desert crossing
Submitted: Tuesday, Jun 22, 2010 at 18:37
mrt
Hi has anybody done the Madigen Line on the
Simpson Desert recently as I need some info, I have done
the desert twice before firstly the french line then the waa line and
rig road but I want a chalenge.
1/I need the projected
fuel usage
2/what sort of conditions could be expected
3/ what permits are required
my e/m is marlyn1@tpg.com.au
Reply By: Polaris - Tuesday, Jun 22, 2010 at 20:40
Just put "Madigan Line" in the search on this
forum.
Plenty of previous threads on the subject.
Tuco
421780
Reply By: Crackles - Tuesday, Jun 22, 2010 at 20:50
1.Projected
fuel usage will depend greatly on what vehicle you're driving & the exact route you choose including which direction. We used around 180L from Mt Dare to Jervois via the
Hay River over 10 days in a 1HZ 100 series. Sand conditions were soft & we had a few short side trips. One petrol Prado in our group carried 500L.
2.From the Acacia reserve there is a section of Gibber stone, low dunes & minor station tracks to
Camp 2. Permits are not available from 3 to 5 so a detour south around the Aboriginal lands to the Colson Track is very challenging. After 6 a visable track is forming in
places with more use between the dunes but dissapears over the loose wind blown crests. The further East you go the more defined the track becomes but at no time will you get out of low range before the
Hay. It's a very slow rough drive, almost an endurance test & absolutely nothing like the easy Simpson drives you've done already.
3.I'll leave permits to others who have crossed in more recent times.
Choose your group carefully as they will need to be self reliant & vehicles mechanically
well prepared.
Cheers Craig.............
421782
Follow Up By: olcoolone - Tuesday, Jun 22, 2010 at 22:16
I'll second that and we used about 250Lts from Mt. Dare to Jervois 6wks ago.
It's not a track you want to tackle with little remote travelling experience or an unprepared vehicle.
A good GPS with good mapping helps a lot due to not being able to see the track in
places.
You will need a desert parks pass for SA side and if you do the
Hay River track you will need a permit for Bookies place available from Joel Flemming in Alice.
692202
Reply By: Member - Stephen L (Clare SA) - Tuesday, Jun 22, 2010 at 21:00
mrt
It all depends of what you thought of the normal Simpson Crossings, eg
1.Very easy with no problems at all
2. Sometimes a little tricky, with no major problems
3. A little hard, but was able to cope.
4. Hard, but was able to get through with some help.
Work on 300 litre of diesel to be on the safe side.
You will only need permits if you are entering from the SA National Parks side.
The Colson will have tracks to follow late in the season, so it should be no problems. If you want a challenge, then head for Geosurvey
Hill and the Geographical Centre.
And by the way, if you did not answer No 1, then it will be hard for you.
421785
