GQ Patrol, what size trans cooler??
Submitted: Thursday, Jun 24, 2010 at 10:22
gonebush SA
Hi, we have a GQ, lwb, 4.2 petrol/lpg, automatic and are trying to make sure about the trans cooler, it does have one on it but from what we can workout it's just the standard one it measures 28cm x 9cm which seems quite small and as we are about to head off towing our van we want to make sure incase we need to buy a new one.
what size do other people use, or is the standard size big enough?, thanks from chris.
Reply By: Clanky - Thursday, Jun 24, 2010 at 15:58
Depends on what you might be doing with it somewhat.
Hauling up the
Vic high country is a bit different to cruising along the freeway etc.
Might be best to slip in a temperature gauge to see what it is actually doing.
The transcoolers are thermostat controlled (bypass) so if you were going to fit one I would suggest the biggest you can fit in a fullflow airstream. When its hot it will be in operation, and when its cold the cooler will be bypassed.
421981
Reply By: mechpete - Thursday, Jun 24, 2010 at 18:57
by one double the size you have and it will be enough , I have doubts about the t/stat controlled thing . but they won,t lock up the torque convertor
until the oil reaches a preset temp . I,m on my 2nd auto GQ , you will have trouble with the trans hunting at 85kph cos that the lock up speed .
They don,t tow
well around the 90kph mark cos of the problem just mentioned . but you can bye a trans locker , and you can adjust what speed you lock the T/convertor .
mechpete .
421999
Follow Up By: gonebush SA - Monday, Jun 28, 2010 at 15:41
hi, we were just thinking about what you have said and as we are about to head off for a 5 week trip, we are now thinking if we would need a trans locker as you have mentioned, can i ask what sort of price was your trans locker as it's all new to us, thanks from chris.
692745
Reply By: gonebush SA - Thursday, Jun 24, 2010 at 19:52
hi, in reply to the above messages, we have a 17.9ft poptop, 1650kg loaded weight and are planning a trip through the
Flinders Ranges and the Eyre Peninsular. and we have just had the trans done up as it wouldn't stay in overdrive and now it's a different car to drive.
thanks from chris.
422006
Follow Up By: mechpete - Monday, Jun 28, 2010 at 18:28
hey Chris ,
when I bought
mine it cost about $450 and it came from a little
electronics bloke in Whitfield in north east vict . Duland electronics !!!
not sure if he is still there .
cheers Pete
692770
