engine ploblems
Submitted: Thursday, Jun 24, 2010 at 21:00
Member - pilbara60 (WA)
need some thoughts on a problem on my 60 series. has developed some sort of miss or something. seems to go in a cycle can be driving and it misses , go a short distance then misses . sounds like a soliniod or something sticking under the dash, has 2h deisel motor. thought it was the immobilizer but still there after replacingit yesterday
Reply By: Member - Tour Boy ( Bundy QLD) - Thursday, Jun 24, 2010 at 21:47
If it is a 2H engine then it will be the edic motor playing up. This can be caused by trailer wiring (don't laugh it happens), low oil pressure, dirty electrical connections or at the outside a faulty injector.
Dave
422029
Follow Up By: Member - Serendipity(WA) - Thursday, Jun 24, 2010 at 23:36
I agree with Dave
Edic motor might be trying to shut down your
fuel. Could be low oil pressure, blocked
fuel filters.
Go through the obvious and easiest solutions first.
The 2H are a great tough motor that takes a lot to stop it.
Any other symtoms.
Another source is on the Lcool site - some knowledgeable guys there for toyotas.
David
692405
Reply By: Member - pilbara60 (WA) - Thursday, Jun 24, 2010 at 21:58
has only just started to play up. was go out
camping last weekend and 20k's out the road it started . didnt want to risk it so turned around and swapped to the misse's landrover freelander
422030
Reply By: Member - Stuart P (WA) - Thursday, Jun 24, 2010 at 23:54
check battery to chassis earths
422043
Reply By: StormyKnight - Friday, Jun 25, 2010 at 00:03
Yep had the same issue, but only when it rained!
Never quite found out the issue but checked & repaired some wiring & also tried a second hard control relay for the
fuel shutoff & board assembly.
Over time it resolved itself.....or was it it stopped raining, before I sold it..... :)
422044
Reply By: Wayne's 60 - Friday, Jun 25, 2010 at 01:12
pilbara60 (WA)
As above replies indicate the most likely cause will be the EDIC motor trying to shut your
fuel off. It is also possible that this incident will change depending on the load on the electrical system and could be an indication of a fault in either battery or alternator and the last time it happened to us at night ..... I removed one end of the control rod, just to get us home under a full set of lights.
Wayne & Sally.
422050
Reply By: Member - pilbara60 (WA) - Friday, Jun 25, 2010 at 18:33
thanks for the help . is a great old truck and have almost setup to where i like it. just dont like things not working properly and is a long way to walk home here in the
pilbara.
422119
