whiteish greyish smoke 97 2.8ltr diesel hilux
Submitted: Friday, Jul 02, 2010 at 19:24
ThreadID: 79800 Views:3809 Replies:4 FollowUps:1
as title says of a night time i see whiteish/greyish smoke from exhaust between 2-4 revs not thick like but noticeable all the same is this just a fuel ratio problem running rich etc ? or something more sinister engine related hopefully not the later ??
your suggestions are appreciated
oh and thanks exploreoz got my stickers today !!!!
actually sore another 4wd in the merrylands area with 1 the other day too !!!!!!
Reply By: howesy - Friday, Jul 02, 2010 at 19:27
perfectly normal and ratio is probably fine. worry when your mates tell you its blowing a reasonable amount of smoke in the day. Dont look for problems that arent there yet.
AnswerID: 422807
Reply By: Wherehegon - Friday, Jul 02, 2010 at 19:43
Mate I had 2.8D and currently have turbo prado, the hilux did it, the prado does it, nothing to worry about, The old lux will even show a bit through the day more so then the prado normally under heavy throttle. Dont worry about it unless its extreme through the day, eg heavy dark black smoke = over fueling, blue smoke= stuffed engine LOL. Dont worry about it drive and enjoy.The old lux I never reved over 3200, no point, revving the crapper out of it for nothing. Regards Steve M
AnswerID: 422810
Reply By: Member - mazcan - Friday, Jul 02, 2010 at 22:24
hi luxyboy
check your aircleaner if thats clean
i would'nt worry as it's common as said to see a bit of smoke from any engine from that vintage cheers
AnswerID: 422834
Reply By: 3GoBush - Saturday, Jul 03, 2010 at 00:05
I had a similar problem 2 weeks ago, I had It put on a dyno and found it to be dirty fuel.
The problem came after I fueled up at a servo I hadn't used before, after the dyno tune all was good again, the cost was $345 well worth it and no more stress.
AnswerID: 422845
Follow Up By: luxyboy - Saturday, Jul 03, 2010 at 11:20
yeah i was thinking this @ 385 tho i might just wait wanna get my wheels and snorkel 1st and get it dyno'd then with snorkel also noticing a little wobble on right side fron when i hit 80 kms so have that checked too, prob from the pig i ran over when pigging the other week lol
thanks 4 the advice to you all cheers !!!
i tell you what this bloody 4wd'ing is getting adictive !!!!!
FollowupID: 693265
