Power problem with 2006 turbo deisel Rodeo
Submitted: Sunday, Jul 04, 2010 at 01:37
Name Not Found
my 2006 turbo deisil Rodeo is dying when I go up a
hill at about 90ks an hour the temp gauge is also quite high as they seem to be affecting one another does anyone have any ideas
Reply By: Member - dave e (QLD) - Sunday, Jul 04, 2010 at 08:00
could be a few things,when was the last time you checked the air filter,if its starving for air, the air
fuel ratio is out and the engine could be overfuelling,causing it to
cook,on a
hill the turbo will be trying to work but cant unless it gets good air supply to mix with the diesel for a good clean burn,may also be an injector or turbo problem,but these engines are pretty good,might wanna start at air filter,im looking at buying one of these rodeos,other than this prob is it a good rig
dave
422943
Follow Up By: Graham & Lynne - Sunday, Jul 04, 2010 at 09:27
The accelerate pedal brakes out of the floor as is fly by wire and don't get full throttle.
693352
Reply By: Madfisher - Sunday, Jul 04, 2010 at 09:53
Change air filter and
fuel filter first.
Cheers Pete
422957
Follow Up By: kev.h - Sunday, Jul 04, 2010 at 18:26
When my work ute did that it was the
fuel filter -a load of dirty
fuel - change the filter and the problem went away. The temp. goes up because its running too lean
Hope yours is as simple to fix
Cheers Kev
693421
