Warn wont work
Submitted: Sunday, Jul 04, 2010 at 15:05
ThreadID: 79847 Views:3369 Replies:8 FollowUps:2
Hi Guys,
Have a 2 year old Warn winch. Tried to give it a run today as we are going on a 3 week trip in a couple of weeks. All I got was a clunk when trying to operate so power was obviously getting through to the winch but no winch movement.
Any ideas?
Kevin
Reply By: Roughasguts - Sunday, Jul 04, 2010 at 15:18
First thing I would do is clean and retighten all the power lead conections.
Might be just a dodgy conection.
AnswerID: 422988
Reply By: Tonyfish#58 - Sunday, Jul 04, 2010 at 15:44
Take the cover off the solenoids undo all the connections, clean and put back together. Also do the same with the connections at the battery end.
I would think it is most likely to be a bad connection and this will fix it.
If that fails then you may have to look at the contacts in the winches motor. You may have had water in the winch at one time.
Regards Tony
AnswerID: 422991
Reply By: Member - Keith C (NSW) - Sunday, Jul 04, 2010 at 16:52
G/day Kev.Most likely to be an earth cable,Installers use a chassis bolt etc, and these are usually exposed to all sorts of stuff.Remove the connection and wire brush the contact points,lube and retighten, should do it.
AnswerID: 422997
Reply By: Voxson - Sunday, Jul 04, 2010 at 17:24
Yeah, check your earth...
It will make the click sound with no action.
AnswerID: 423003
Reply By: Member - Josh (TAS) - Sunday, Jul 04, 2010 at 18:29
How often do you run the winch when not in use. We put these things through so much abuse and often let them sit there for months/years when not needed then expect them to work when needed. It only takes a small amount of water to do damage when sitting idol. I'm not saying this is what you have done but a timely reminder for those with winches to give them a test run to keep them working well. Spray it with wd 40 or similar to help lubricate it all.
Josh
AnswerID: 423011
Reply By: Member - Kevin R (QLD) - Sunday, Jul 04, 2010 at 20:21
Thanks for the replies guys. I've checked all the connections but being very unskilled at auto electricianing I forgot about the earth. I'll have a crawl around during the week and see what I can find.
Kev
AnswerID: 423028
Follow Up By: Tonyfish#58 - Monday, Jul 05, 2010 at 16:31
Kev - By check I hope you mean undid, cleaned and replaced :-)
Otherwise may I suggest..... go do it all again :-)
Cheers Tony
FollowupID: 693506
Reply By: Tonyfish#58 - Monday, Jul 05, 2010 at 16:33
P/S You can check the solenoids with a 12v test light. Check if you have power going in to them and when you activate the Winch switch check if it is going out to the motor
AnswerID: 423106
Reply By: geocacher (djcache) - Monday, Jul 05, 2010 at 22:44
If it's been in any river crossings the brass ring housing the brushes which is only pressure connected to the motor housing develops a bit of oxidization and causes similar problems.
Clunk is likely to be the solenoid engaging so I'm tipping no problem there.
Connections, earth or ring mount are likely problems.
SG Leslie recommend drilling & tapping the motor housing and screwing the brass brush housing to it to prevent the problem.
Also, who fitted it? Did they rotate the motor to get the drain holes oriented correctly? Or has it been sitting half full of water for months since your last river crossing?
You can make them more water proof. I'm pretty sure there are still instructions for a service on my website - which is still around but hasn't been maintained for a long time - I suggest you maintain winches much more frequently than the site gets updated :o). Must get the courier off it.... sold that yonks ago.
Dave
AnswerID: 423186
Follow Up By: geocacher (djcache) - Monday, Jul 05, 2010 at 22:48
Yup. It's there. Just checked. Link under other in left tool bar on http://4wdstuff.davejones.com.au/subdomain/4wdstuff/
Dave
FollowupID: 693572
