Friday, Jul 09, 2010 at 19:00
Dont know much about the $790 kit. But it sounds good if it works as described.
There are many unknown brands of shock and spring combination that will do the job very
well. Problem is most of us will go for the Branded name Lovells, ARB, OME, Iron Man, Tough Dog the list goes on and on.
A Coil spring is a coil spring provided it is engineered correctly and not overstressed. Overstressed springs sag quickly. If the correct rate spring is chosen then there is no problem. Shock absorbers are what makes the
suspension good or bad. Correct valving and resistance to fading are very important. In this respect size does matter and gas is better then just an oil shock.
Problem is good shocks are expensive and that is not to say some of the cheaper ones are junk. In the end it all depends on what use you are going to use them on. I have seen shocks burn the paint off the outside due to the heat build up under harsh conditions and that is why you see off road vehicles fitted with 2 or more shocks per wheel. Doing this means the individual valving of the shock can be softer and hence less heat is generated.
I have Pedders on my HJ80 it came with them, they are ok for normal off road touring that most of us do. I have found that Polly air bags are needed if carrying a reasonable load just to keep the vehicle from being low in the back.
Its great to read other peoples comments on the
suspension they have fitted and to read some non payed for articles on the various setups available.
In many cases the most expensive is not necessarily the best for your application.
Wayne B
693946
