The caravan guide to Millstream National
Park.
Millstream National
Park is 150 kilometers east of
Karratha in Western Australia. It is a arid plateau spinifex, ex-cattle station at about 600 meters elevation.
Getting there is via a mining road to Mt
Tom Price for the first 90 kilometers sealed then another 40 or so of Class 3, (all weather) unsealed. Part of this sealed section contains a significant
hill, that although not steep is long and can be a grind for a lower powered tow vehicle. The gravel road is only slightly corrugated and can be driven at about 70 to 90 kilometers an hour.
The
park itself is in 2 main sections. The
Python Pool and the
Homestead section. They are located about 60 kilometers apart so staying at one and visiting the other is quite a drive. The
python pool section is 19 kilometers after the sealed road ends and both have
camping and
toilets.
The
Homestead section has the
visitors centre and itself has 3
camping areas.
Homestead, star gazers and Crossing pool.
Homestead is best for caravans as there are 20 sites there about half, with some form of shade. They are built around a large ring road. Others are perfect for caravans that need solar during the day.
Homestead also allows generators between 9am and 7 pm, both the other campsites are generator free. The facilities at
Homestead are the most modern, with 2 excellent composting
toilets and a
camp kitchen with hot
water and gas stove.
Homestead is also ideal for sat tv. The
visitors centre is about 100 meters away. There is also a untreated
water tap. There is no tap for refilling a caravan within the
camping area.
Crossing pool is much smaller and has an older feel about it. Campsites are “pick somewhere” within the marked area. Most are under shade cover and there is no availability for
solar power nor sat tv. Suitable for a small caravan or camper trailer. There is enough room for about 15 campers. Very tight for turning a large caravan around. The trees are beautiful and filled with Corellas in the afternoon.
The pool there is several hundred meters long and perfect for swimming, fishing and canoes. The
water is very very cold.
Stargazers
camping area is closed during quiet times and is something of a
overflow area. There is little there.
There are graded gravel roads around the
park to lookouts and two walks. The walks are interesting and vary in hardness.
Park fees are $11 per vehicle entry and $7 per person per day to
camp. As you might imagine there is no cell phone coverage.
Generally speaking it is an excellent
park.
