Beaudesert 3'' Mandrel Bend Exaust System Nissan Patrol 4.2 TDi
Submitted: Wednesday, Jul 21, 2010 at 05:32
Ozymacca
I just installed the
beaudesert 3'' system on my Nissan Patrol 4.2 TDi, I should have installed this seven years ago what a difference this has made the only problem I had was the written instruction sheet from
Beaudesert how to install the system did not explain the mounting brackets setup so I have pasted a link below with pictures as to how the mounting brackets are set up on My Nissan Patrol. I hope this helps anyone else installing this system.
Cheers Macca
http://www.flickr.com/photos/8188630@N03/
Reply By: Hairs & Fysh - Wednesday, Jul 21, 2010 at 06:40
Hi Macca,
The link isn't working. Bugger.
I know
mine vehicle is a Yota, but same size motor & Turbo.
Installed a 3" on the 80 early last year, made a huge difference.
Mine was from Scotts Rods. off eBay.
The old girl doesn't work as had towing the Swan and when 4Wdriving it has a lot more down low grunt. Better
fuel economy as
Just under 600 bucks, money
well spent I reckon.
424691
Follow Up By: Member - Andrew (QLD) - Wednesday, Jul 21, 2010 at 07:35
Follow Up By: Hairs & Fysh - Wednesday, Jul 21, 2010 at 07:41
Cheers Andrew those links work. :)
695156
Follow Up By: Maîneÿ . . .- Wednesday, Jul 21, 2010 at 11:55
Andrew,
the Blue Fin is a gr8 fishing platform, the Yammie would push her along nicely too :-)
Those roasts all look really fantastic, will have to look into a Cobb now
Maîneÿ . . .
695190
Follow Up By: Member - Andrew (QLD) - Wednesday, Jul 21, 2010 at 12:00
Not my photos ;) Just had a gander myself Mainey, and i agree about looking into a Cobb now :) That lamb roast seems the go.
Andrew
695192
Reply By: Member - Oldplodder (QLD) - Wednesday, Jul 21, 2010 at 08:05
Yep, put
Beaudesert 2.75" system on the pajero, (hey, it is only a 2.8l motor), and noticed the difference. Turbo spools up about 200 rpm earlier, slightly more power and the EGT generally reads lower by maybe 20 degrees. Turned the
fuel up slightly and still getting slightly better economy with more power.
Pluses all round, and it sounds good too. :o)
424696
Reply By: Ozymacca - Wednesday, Jul 21, 2010 at 15:50
So sorry, I pasted the link early in the morning. I will try again.
Cheers Macca
Beaudesert 3'' Exhaust fitted to Nissan Patrol 4.2 TDi
Hope The link above works
424755
Follow Up By: Member QLD Steve & Lorraine Mc - Wednesday, Jul 21, 2010 at 17:18
Hi Macca,
All you need to now is take your Patrol to a reputable diesel tuner, with a dyno & adjust the timing, take the boost up to 12+psi and a touch more
fuel and the difference will be amazing.
Cheers Steve.
695224
Follow Up By: Hairs & Fysh - Wednesday, Jul 21, 2010 at 19:17
Cheers Macca,
You wont regret fitting it.
695241
Follow Up By: Ozymacca - Friday, Jul 23, 2010 at 17:21
Hi Steve & Lorraine,
Thanks for your input I will look into your suggestion. I hope someone can point me in the right direction as to where to get this done. I live in the Penrith area NSW.
Thanks Macca
695469
Reply By: Member - Geoff A (VIC) - Wednesday, Jul 21, 2010 at 17:47
Hi Ozymacca,
What's the noise level like with the BD exh?
Do you notice any droning inside the car?
Geoff
424769
Follow Up By: echucabarry - Wednesday, Jul 21, 2010 at 18:19
Ozymacca, I have noticed a slight, albeit very slight, droning sound but quite bearable. What I have noticed is an increased heat level through the floor on the passenger side . Anybody else noticed this ??
695230
Follow Up By: Hairs & Fysh - Wednesday, Jul 21, 2010 at 19:27
Yeah, I have guys.
Especially on a freeway, sitting on 110kph.
But i don't feel any heat coming through on the 80. It runs under the drivers side and I don't feel any abnormal temp change. Might be different in a Patrol down the passenger side.
695244
Follow Up By: Member - Michael and Chris (QL - Wednesday, Jul 21, 2010 at 20:52
Mine has a
water cooled garret turbo on a high mount denco manifold. I have wrapped the dump pipe with some heat shield which has solved that problem. As for the droning I fitted a small 3" straight thru muffler which
Beaudesert could not supply at the time. It just takes the edge off and you mostly hear turbo whistle. If you have a Patrol ute you don't have the droning problem.
695259
Follow Up By: Ozymacca - Thursday, Jul 22, 2010 at 03:27
Hi Geoff,
The patrol is actually very quiet no droning problem. The exhaust system has a 3'' straight through muffler. I expected it to be louder.
Cheers Macca
695301
Follow Up By: echucabarry - Thursday, Jul 22, 2010 at 20:28
Full credit to
Beaudesert Exhausts, I raised the issue of heat through the floor with TJM
Bundaberg , who installed the system. TJM sent a set of photos to
Beaudesert who could not see any irregularities. TJM installed further heat shield insulation under passenger side and problem is nowhere near as noticable, if at all. BUT Beaudesrt Exhausts, to their credit, also extended an invitation to call in there and have unit personally inspected if I still felt there was a problem. Doubly impressed with good service/s.
695376
