Toyota Hilux Lights
Submitted: Friday, Jul 23, 2010 at 12:51
ThreadID: 80259 Views:4101 Replies:2 FollowUps:0
My 2000 4WD Toyota Hilux has one headlight that only works when on high beam.
I'm pretty ignorant in these matters but assume it's a fuse?
Can anyone suggest what the issue might be and how to solve it?
Cheers, Stu
Reply By: Member - Tour Boy ( Bundy QLD) - Friday, Jul 23, 2010 at 12:59
Nope blown filament unless it has a slight glow (like a parking light) then it is the fuse.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 424994
Reply By: Mark S (cns) - Friday, Jul 23, 2010 at 14:21
As said, the low beam filament is gone.
If it is an original headlight (i.e not been replaced before) then you will have to replace the entire headlight, not just a bulb, as these are a sealed unit (I know - I have one). These rectangle headlights are common on many vehciles, not just hilux.
Can do one of 2 things:
1/ Buy a new aftermarket pair from ebay, that are designed so you can change the bulb. I did this on a previous vehicle, cost about $60-70 for the 2 headlights, and end up with a better light than the original.
2/ Buy a single rectangle sealed beam type unit that you currently have from an autoparts shop - cost about the same as the ebay ones, but not as good a light.
Mark
AnswerID: 425001
