Hilux Engine 3 Litre 4 Cylinder Diesel NA (2002)
Submitted: Monday, Jul 26, 2010 at 11:49
ThreadID: 80315 Views:4592 Replies:3 FollowUps:3
Hi.
Threw a rod out the side of a Hilux. Look for any recomendations for a rebuild or exchage engine supplier around Brisbane or SE Qld. The block is worth nothing now, but still need to get an engine back in to it. 170K's so it still worth doing.
Thanks for any info.
Simon
Reply By: Member - Tour Boy ( Bundy QLD) - Monday, Jul 26, 2010 at 12:01
Hunt around the wreckers for the factory 3l turbo (early not the D4D) may even have the same engine mounts althiugh a stronger clutch may need to go in.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 425259
Follow Up By: Lex M (Brisbane) - Monday, Jul 26, 2010 at 19:52
"although a stronger clutch may need to go in. "
As well as the ECU, wiring harness etc.......
FollowupID: 695849
Follow Up By: wjh41 - Monday, Jul 26, 2010 at 20:22
A friend of mine did that conversion.He brought another damaged vehicle to swap all the necessary parts over including the gearbox/transfer case.The front engine mounts had to be moved,the rear mounts lined up and the tailshaft fitted okay.The dash and ignition wiring had to be changed and as Lex said ECU etc. Although a very time consuming job it was a worthwhile conversion.1 drawback was that 5th gear is a different ratio and the speedo was out but bigger tyres would help fix that.
Good luck Wally
FollowupID: 695859
Follow Up By: wjh41 - Monday, Jul 26, 2010 at 20:37
Sorry his vehicle started as a 2.8lt
Wally
FollowupID: 695868
Reply By: Member - Chris & Debbie (QLD) - Tuesday, Jul 27, 2010 at 12:04
Simon
Depending on where and how bad the damage is you may be able to patch the block.
If you can do the work yourself and it is has only a broken rod and no other major damage you can get away with just replacing the rod and a weld repair done to the block, Its a cheap option if thats what is needed.
Chris
AnswerID: 425376
Reply By: Mark S (cns) - Friday, Jul 30, 2010 at 15:43
Try Qld motor recyclers (QMR) in Rocklea.
QMR
I have dealt with them before in getting parts.
Mark
AnswerID: 425750
