Wheels for BT50
Submitted: Wednesday, Jul 28, 2010 at 00:38
Holentheroad
I'm looking for some advice in relation to the
wheels on my BT50, dual cab with fibreglass canopy, I wish to use 16inch
wheels rather than the 15inch supplied. Is this OK? And if so, is there anything I should be aware of?
Best regards
Reply By: Muntoo - Wednesday, Jul 28, 2010 at 01:06
I take it you have the DX model. I have the SDX model and it comes standard with 16''
wheels. Shouldnt be any hassles at all, apart from tyres costing more.
425469
Follow Up By: happychap - Wednesday, Jul 28, 2010 at 13:44
The diff ratio is different between the models that have 15 ¨ and 16¨
wheels. Check the Mazda website. Performance, speedo, and distance travelled would all be affected somewhat.
696028
Follow Up By: Holentheroad - Wednesday, Jul 28, 2010 at 16:14
Thanks, That's what concerns me! I'll follow up on the Mazda website although they give very little info.
696038
Reply By: Geoff M - Wednesday, Jul 28, 2010 at 15:38
The 16inch
wheels should be fine, depending on what tyre size you choose. I'm running 15inch rims with 31x10.5R15 tyres which just fit (also have a 2" lift via
suspension upgrade). With these tyres the speedo reads exactly right (is 5% out with the standard tyres).
Geoff
425529
Reply By: Member - Serendipity(WA) - Wednesday, Jul 28, 2010 at 18:22
I believe if you check your tyre chart on the door style it states you can use either 15in or 16in on the Mazda. This has been the case even with the older Mazda bravos.
425557
