Air Bag Leak
Submitted: Wednesday, Jul 28, 2010 at 16:14
jeep cherokee
Hi all. I have recently discovered a pin prick(and i mean small)of a leak on one of my blue air bags.The leak is right where the top of the bag is moulded to the brass ring next to the air hose.I have no idea what make they are by the way.The qusetion is,can the hole be sealed by any means,eg: glue or plastic welding or any other way as a new pair will be an expensive option.
Reply By: Member - Vic S (VIC) - Wednesday, Jul 28, 2010 at 16:22
I think you should find the brand and if possible the date fitted as there may have a warranty that would be voided if you try to repair.
Vic
425531
Reply By: Shaker - Wednesday, Jul 28, 2010 at 16:29
If it is a Firestone Coil Rite airbag they did have an issue with a batch leaking around the brass inlet hose insert & were replacing them under warranty.
Check with the Airbag Man.
425532
Reply By: gbc - Wednesday, Jul 28, 2010 at 17:02
I has success with zlysshh - that tyre repair stuff in a pressure pack. I was sick of the air fittings leaking and did it as a last resort. Wish I did it first now.........
425537
Reply By: jeep cherokee - Wednesday, Jul 28, 2010 at 17:50
Thanks for those replys.The car is second hand and the bags were in them already so i don't have any chance of getting them replaced, however i will try the tyre repair stuff,nothing ventured nothing gained as they say !!!
425549
Reply By: Going Bush - Wednesday, Jul 28, 2010 at 18:03
On a tour of the USA we bought a 2nd Hand Lincoln Continental and it has Airbag
suspension, Which did start leaking as we went on some tracks in Deliverance country Im sure a Lincoln has never been on before , We were lucky to get out with the rear
suspension on the bump stops.
Used same remedy as gbc and squirted Green Slime (similar puncture repair tyre goo as seen in SuperCrap Autos) into the system behind the pump, Fixed the problem & lasted another 6 weeks without trouble !!
425554
Reply By: Batt's - Wednesday, Jul 28, 2010 at 22:22
G'day I had the blue air bags on a dicco from air bagman 5yrs ago their rubbish and are notorious for letting go at the top I went threw 2 sets both lasted about 1,000k's each from
Perth to Mackay Pollyair bags are the best way to go a 4wdrive outlet in
Fitzroy crossing told me he wouldn't touch the blue one's but he would only fit pollyair I got my money back but had to pay to get them taken out I have pollyairs in my patrol 4yrs old still going strong
425607
