new ford ranger stuttering shudder automatic
Submitted: Wednesday, Jul 28, 2010 at 20:43
navara07
Good day all I have a Ford
ranger XLT Auto D/Cab 1600km on the clock when reversing or going foward 1000rpm get a stutter/shudder like letting clutch out on a manual to fast I thought very odd for a auto gearbox very simular feeling when trying to start off with the gear lever in third gear anyone else had this problem going back ford soon to me feels like a tailshaft problem but then again through out driving gear and rev range no problem may be gears slipping in auto box,
Thanks for your replys.
Reply By: Member - Graham H (QLD) - Wednesday, Jul 28, 2010 at 20:52
Get the handbrake adjusted My cruiser does that if I dont drop the lever far enough.
425592
Reply By: Members Paul and Melissa (VIC) - Wednesday, Jul 28, 2010 at 20:52
could be the auto slipping. i had a similar shudder in a new VP i bought in 93. when you accelerated fairly hard it would do it, but after a few thousand k's it stopped. apparently the clutch packs just took their time absorbing ATF so you may have a similar thing. if its still there at next service maybe tell the dealer about it.
425593
Reply By: Member - Ian H (NSW) - Wednesday, Jul 28, 2010 at 20:53
Navara,
I have had experience with a
Ranger that shuddered heaps at take off.
It was caused by the tailshaft centre bearing mount being too high causing too big an angle in the tail shaft.
Ford (Maxda) have a fix where they fit a spacer block between the chassis and centre bearing to lower it and reduce the shaft angle.
Hope this helps.
Ian
425594
Reply By: navara07 - Wednesday, Jul 28, 2010 at 21:24
I know some BT50/Ford Rangers will shudder with a lift kit some do and some don't my car has standard
suspension.
My mates BT50 did shudder put 2 washers in the centre bearing shudder vibrations gone with 2 inch lift kit ironman.
425602
Reply By: navara07 - Wednesday, Aug 18, 2010 at 10:22
any others with this problem ????...
427567
