Prado/Flat Battery and power windows
Submitted: Thursday, Jul 29, 2010 at 21:16
Cruiser .
Had a flat battery last night, so had to replace it this morning.
After connecting the new battery I recoded the radio, but none of the passenger windows could not be operated from the drivers controls, however, each window could be operated from its own switch.
After much hair pulling it was discovered that the solution was to lower each window, then raise it and hold the switch in the up position for 6 seconds.
Apparently each window has a travel sensor built into it and when the power was lost, the window system needs to be reset so the travel sensors can work.
If you have a Prado and loose power, best remember this procedure
Cruiser
Reply By: Member - William B (The Shire) - Thursday, Jul 29, 2010 at 21:33
Hi Cruiser,
I have come across this problem before,
the procedure is outlined in the owners manual.
Thanks for the heads up,
William
425694
Follow Up By: Fab72 - Friday, Jul 30, 2010 at 08:25
Pfffft...who reads that?
696242
Reply By: Member - Charlie M (SA) - Thursday, Jul 29, 2010 at 23:01
Hi Cruiser
power each window down and hold button down for a couple of seconds then back up and do same, then should work ok some times I have to do a window twice.
Charlie
425703
Reply By: Member - Toyocrusa (NSW) - Friday, Jul 30, 2010 at 06:23
Now ya tell me (LOL) Took
mine back to the dealer recently for the same thing. Bob.
425712
