Vacuum packing on the move
Submitted: Saturday, Jul 31, 2010 at 12:34
ThreadID: 80432 Views:5049 Replies:7 FollowUps:6
There was a thread a while back about cryovacing food. Fond this little gem while out and about today. Uses a 240v adapter (ie runs off DC) so should be good for taking with you on the road. Uses re-usable bags too.
Breville VAC2PAC
Reply By: Maîneÿ . . .- Saturday, Jul 31, 2010 at 13:07
The idea of "resealable" bags may not be a benefit on the road, as they could cause contamination to the next product to be stored in them, just a thought.
Maîneÿ . . .
AnswerID: 425819
Reply By: Shaker - Saturday, Jul 31, 2010 at 13:20
Sunbeam have a rechargeable cordless one now as well, about $79.00
AnswerID: 425823
Reply By: Charles Jenkinson - Saturday, Jul 31, 2010 at 13:21
I use a similar product - the Snunbeam Foodsaver Vac420. It runs fine off a 150W inverter (although it works much better when the inverter is plugged into a power socket connected directly to the battery by alligator clips.
We use it to pack meat and perishables when touring. Easy to vacuum pack it in the car park, and stick it straight into the Engel.
Not sure if I would reuse the bags either... but the vacuum bags are fairly cheap anyway. Might do if I gave them a good wash...
Charles
AnswerID: 425824
Follow Up By: Patrol22 - Sunday, Aug 01, 2010 at 12:30
Can't remember the full details of the Vac420 but I seem to remember that they draw 300 watts....which, if I am right, is overloading that inverter. I run mine off a 500 watt inverter and it runs like a dream.
FollowupID: 696423
Follow Up By: Charles Jenkinson - Sunday, Aug 01, 2010 at 13:02
Checked the book prior to purchase, and just double checked - 240V 50Hz 105W. Not overloading a 150W inverter :-)
You had me worried there for a second, because it would be easy enough to misread a power rating. In any case, a larger inverter is on the cards, probably for our trip to Carrawine Gorge/Skull Springs/Karijini next year. 150W has seen us through this far...
Thanks for your input, Patrol22! Worth the double check for safety's sake.
Charles
FollowupID: 696432
Follow Up By: Patrol22 - Sunday, Aug 01, 2010 at 13:15
Just rechecked mine as well and you're right 105 watt it is.....must have something else in the kit that runs 300 watts and I'm suspecting that it is the 15 inch LCD TV now I come to think of it.
FollowupID: 696433
Reply By: Expletive - Saturday, Jul 31, 2010 at 17:55
Mr Bitchi,i bought 4 plastic containers smallish type could hold 6 av size steaks,Or 1/4k bacon 1 doz thin beef snags & what ever else you would like to fit in them they were silicone sealed from annaconda just as good as vacuume seal & wash out & use again.
Had no problem with any item going off over 6wks.
Bob.
AnswerID: 425842
Reply By: D200Dug- Saturday, Jul 31, 2010 at 19:20
The new inventors last week had someone cooking food in the bag in a water bath.
It looked like a really interesting method of cooking
AnswerID: 425849
Follow Up By: WillyWish - Saturday, Jul 31, 2010 at 19:46
I would never cook anything in plastic....we already surround otherselves with far too much plastic that's most likely causing us all sorts of health problems, let alone environmental problems. Imagine the chemical leaching from plastic to food when heated.....
FollowupID: 696384
Follow Up By: D200Dug- Saturday, Jul 31, 2010 at 19:53
We are surrounded by all manner of chemicals. After years of working in darkrooms and being on of the guys who was inside the toxic F111 fuel tanks I doubt a little bit of plastic will make any difference to my health.
FollowupID: 696385
Follow Up By: Member - Bucky - Sunday, Aug 01, 2010 at 05:59
WillyWish
Would you trade palstic for Aluminiun ,,??????
Then you will not remember anything about anything else.
Alzyhyhmers link with that one !
Then it's choose your poison, isn't it.
Cheres
Bucky
FollowupID: 696407
Reply By: Sand Man (SA) - Sunday, Aug 01, 2010 at 09:54
Our "home" Vacuum Preservation System draws 110 watts so I would have no hesitation of running it off the 300 watt inverter I carry in the vehicle.
As we are seldom out for more than a couple of weeks at a time, we have no need to take it with us, as the quantity of food to be sealed leads to preparation at home before heading out.
Bill.
Bill
AnswerID: 425884
Reply By: Member - Mark G Gulmarrad - Sunday, Aug 01, 2010 at 10:18
Has lefty started to make you pack your own lunch now??
AnswerID: 425887
