Too hard suspension
Submitted: Thursday, Oct 23, 2003 at 23:46
Auto
Hi!
I have another problem with my Pajero mentioned PostID: 8038. I satisfied with the standard
suspension when traveling outback but cause pain in my back in the city especially in Budapest town of pothole. Sometimes medicin necessarry. May i change softer dumping or/and spring or fell the air off from tyres?
Thanks in advance
Reply By: joshinthecity - Thursday, Oct 23, 2003 at 23:56
If it was me, I'd be inclined to go to a
suspension specialist to get your dumpers and springs professionally diagnosed. But DO NOT fell too much air from the tyres. You could find them coming off the rims.
J.
34930
Reply By: ontopic - Friday, Oct 24, 2003 at 01:44
Auto you should have a chat with previous poster dlatus as you speak
the same language.
34934
Reply By: GQfisho - Friday, Oct 24, 2003 at 07:49
There's always adjustable shockers from rancho and tough dog. approx $400/pair.
Haven't tried any of them but being adjustable they should give you best of both worlds.................
34937
Reply By: Les from Lovells Springs Central - Friday, Oct 24, 2003 at 15:01
Why not contact Lovell's Springs and check out what they can do for you, they can put together a kit that will be what you want.
34983
Reply By: phil - Friday, Oct 24, 2003 at 15:39
How much air pressure do you have in the tyres?
If it is over about 30psi it may be too much around town (and on dirt roads!)
34985
Follow Up By: carazy merredin wa - Friday, Oct 24, 2003 at 20:33
Phil, i agree. Because my lower back is dicky, I've experimented with tyre pressures & I can tell you that 4 psi lower pressure can make the difference between a harsh ride & a plush ride. I now personally run with about the lowest pressure I can-28 psi.
25311
Reply By: Mickl - Friday, Oct 24, 2003 at 20:14
If the only problem the
suspension is causing you is a pain in the back why not consider a
suspension seat?
35019
