hour meter
Submitted: Tuesday, Aug 03, 2010 at 13:13
ThreadID: 80489 Views:3484 Replies:3 FollowUps:3
Hi to all just bought ef2000is yamaha genny from the campinng show in Adelaide,also have a sendec hour meter any pic out there on where to put this meter dont want to drill any holes if i can help it thanks Stan.
Reply By: roberttbruce - Wednesday, Aug 04, 2010 at 14:44
Hi Stan,
Im not sure where to put the meter as with mine i guage the oil changes by the amount of fuel i put through it, ie, every two tanks change the oil...
My ef1000is has now done 9000hrs... I didnt run it flat out as often as required so the exhaust system chocked up with carbon after the first 6000hrs...
I also found running penrite30 far better than yamalube and valveline...
Well done on your purchase, they are a much fresher design than the common honda..
NB - no affiliations
AnswerID: 426166
Reply By: jdbb - Wednesday, Aug 04, 2010 at 19:01
I just fitted an hour meter to ours. It's one of those Briggs & Stratton ones with a wire that wraps around the spark plug wire, and another to earth.
I fixed the meter to the end of the generator where the power points are, and snaked the wires up thought the vents at the top left hand side of that end. No holes drilled - looks neat.
regards
AnswerID: 426191
Follow Up By: Member - Patrick (QLD) - Saturday, Aug 07, 2010 at 14:53
Pardon my ignorance but where did you run your earth wire to?
Patrick
FollowupID: 697067
Follow Up By: jdbb - Sunday, Aug 08, 2010 at 19:24
Just undid one one the bolts on the generator and connected to that.
regards
FollowupID: 697202
Follow Up By: Member - Patrick (QLD) - Monday, Aug 09, 2010 at 03:40
Thanks John.
I can now go forth and fit mine with a bit more confidence.
Patrick
FollowupID: 697287
Reply By: stans truck - Saturday, Aug 07, 2010 at 13:33
thanks guys for your input regards Stan.
AnswerID: 426493
