gas system
Submitted: Wednesday, Aug 04, 2010 at 21:31
Member - david m2 (SA)
What are the best brand LPG systems to have fitted. i am looking at installing one on a v8 petrol cruiser.
Reply By: snapper49 - Wednesday, Aug 04, 2010 at 22:10
go and see keith Garner at northern auto gas at elizebath
he is an expert in this field and does a really excellant job
426216
Follow Up By: bloosted - Thursday, Aug 05, 2010 at 09:24
untill you have a problem and have to take it to qld too get fixed
696799
Follow Up By: snapper49 - Thursday, Aug 05, 2010 at 10:53
Dont know about your beef??
but he has installed over the year a doz or so gas system for myself and people I have put onto him
not one complaint
My latest system is a sprint system fitted to my ford territory -all good
I m sure he now has a v8 toyoto cruiser himself on gas
696808
Follow Up By: bloosted - Thursday, Aug 05, 2010 at 16:49
yep he has a V8 cruiser himself and goes great, i have had him put 5 systems on my own cars and yes sent him some too but the last one he did for me was my cruiser and i took it back 10 times...yes 10,and in the end he said it was a problem with my car, finally whilst on holiday in QLD i had enough and rang sprint head office who sent me to a dist over there and they fixed it in 1/2 hour but wouldn't cover it under waranty because it was installed incorrectly and Keith wouldn't reimburse the $120 so lost me as a customer and can't reccomend him anymore,just my exp and won't hijack this thread anymore
696828
Reply By: Best Off Road - Wednesday, Aug 04, 2010 at 22:23
David,
I've got the Prins Injected Gas on My V6 Courier. Had it for 2.5 years and it is excellent.
Jim.
426218
Reply By: rags - Wednesday, Aug 04, 2010 at 22:37
Not sure what brand is best but the newer type injection systems seem to be the way to go.
I did have a scary moment today refilling my work ute [Ford FG Falcon ute with dedicated Egas 3months old] .When the
tank was full and the bowser cut out i could not release the pump trigger as it would then allow gas to escape at the nozzle at a great volume. I had to get the attendant to kill the safety switch to pump to release pump pressure which allowed me to release the trigger and then remove from car.I drove straight to the Ford dealer who inspected the car and confirmed that it has a faulty pressure valve on the filler pipe and is also slightly leaking now. I now have got to drive the car untill
tank is near empty then bring it back for necessary repairs on Friday. [also informed that this car model is also subject to a progressive recall to have the auto tranny replaced and ford will notify as new boxes become available].Not sure if this incident would be considered an isolate event ,but it was suggested that it happens as a result of dirt/grit getting into the filler connection pipe when refilling causing the valve seal to be damaged.
goodluck
Russ
426220
Reply By: Road Warrior - Thursday, Aug 05, 2010 at 15:49
Steer clear of the Romano SVI system, its rubbish.
426266
