Towing mirrors
Submitted: Friday, Aug 06, 2010 at 23:04
ThreadID: 80564 Views:3635 Replies:8 FollowUps:0
I have recently purchased a boat. I now find I can not see past the boat through the standard mirrors in our Prado. Can anyone give us some advice on suitable towing/extension mirrors?
I assume there are good & bad ones. Any advice would be great.
Cheers Tooley
Reply By: Member - Patrick (QLD) - Saturday, Aug 07, 2010 at 02:39
Have found the Aussie Truck mirrors to be the best. No vibrations or swing back with passing tucks. Wurth the $$$ in my opinion.
Patrick
AnswerID: 426437
Reply By: Ray - Saturday, Aug 07, 2010 at 08:02
I've tried many of the commercial towing mirrors none of which were very successful so I made my own. They are made from RHS and clamp onto the roo bar with 'U' bolts. The arms are telescopic and are removable from the "U" bolted section on the roo bar. The mirrors that I have used are convex. By using convex mirrors vibration is not a problem. I also have a rear view camera.
AnswerID: 426449
Reply By: Member - KC (TAS) - Saturday, Aug 07, 2010 at 08:59
Hi Tooley, have a read through these , that might help a bit. Good luck with it.
AnswerID: 426453
Reply By: Member - mazcan - Saturday, Aug 07, 2010 at 12:54
hi tooley truck mirrows and a camera
but beware that convex mirrows make the vehicles behind look further away than what they actually are and some camera systems also do that as well
so be carefull when overtaking and/or merging it's easy to mis-calculate the clearance behind your towed item
AnswerID: 426486
Reply By: oldpop - Saturday, Aug 07, 2010 at 16:54
Be quick with Aussie Truck Mirrors when current stock gone closing shop no more mirrors
Oldpop
AnswerID: 426508
Reply By: D200Dug- Saturday, Aug 07, 2010 at 17:26
I saw what looked like a really nice set of electric extension mirrors in the ARB catalogue but at $660 a pair I think I will make do with what I have :-(
AnswerID: 426510
Reply By: Member - Vince M (NSW) - Saturday, Aug 07, 2010 at 20:32
I fit a camera to the trailers (7.5mtr boat) that I supply to NSW maritime & have had no problems 110* h/duty commercial from polaris
AnswerID: 426539
Reply By: TOOLEY - Tuesday, Aug 10, 2010 at 00:19
Thank you for all the advice.
Cheers Tooley
AnswerID: 426805
