Hi guys,
It's been so long since I posted here I've had to create a new username !!
Ive searched all the threads and also the www but haven't quite got my answer nor a solution to my problem....
History: ...(just added for colour and background...)
Years ago I purchased an EvaKool ED40L fridge, a 50watt BP solar panel and upgraded my main battery to an Exide N70ZZ. We went around Oz running the fridge with little problems straight off the main battery. On extended stays and way up North in the hotter climates (Arnhem,
Broome etc.) I would run the truck on fast idle (2000rpm) both mornings and evenings for 10-15 minutes to ensure we were topped up. The fridge would occasionally stop overnight dependent on the overnight temp, but no major hassles.
I had no
tools to measure the charge, I learnt from experience and it just worked. Although once in
Innamincka before I had it all sorted out we did run flat..that was pretty funny really..pack up
camp..oops, flat battery..put solar panel onto battery..set up
camp again..stay another night..ah
well !
Later on I extended this system to a second N70ZZ in the rear of the ute and ran a 100amp Redarc isolator to charge. I could then run radio from the main all night, long-life low voltage flouros and the fridge from the aux battery and everything was even hunky-ier dory-ier.
I was running 3mm auto wire to the aux battery, didnt seem to be an issue, aux. battery charged fine and lasted for years and years.
Problem:
Just recently, on an extended trip I replaced my weary batteries and decided to get a fullriver sealed 85amphour for the aux battery. Main battery still another N70ZZ. I upgraded the positive lead to 8GA cable and also beefed up the neg wires - a 'home made' multi strand earth strap to the 'lux rear chassis.
On this trip I had nothing but trouble, the redarc was unable to fully charge the fullriver resulting in a conked out fridge sometime during the night. It got to the point that I gave up and simply ran the fridge, whenever possible, straight out of the cig lighter connection off the main battery.
I could only charge to around 12.5 volts (from memory) which just wasn't enough to run the fridge for any length of time. Since Ive been back I've put the solar panel on and chrged up to 13.1V which runs the fridge fine for hours and hours.
Summary: The only thing that has changed in this setup after years of no problems is the change to the fullriver battery and some wiring upgrades (agreed I probably should be using 4GA but its still a vast improvement over what was there).
Summary:
Car: 1999 Hilux, 55amp alternator
Aux. Battery: fullriver sealed lead acid 85amphour
Wiring: 8GA positive and earth - 4mm / 56Amp
Battery Isolater: Redarc CP12V 100amp - Off V:12.5 On V:13.5
Max batt. charge on redarc: 12.5V
Max batt. charge on Solar panel:13.1V
Q's...
1. Multimeter says the aux battery charges to 13.1v at the most. I believe this battery (fullriver DC85-12) should charge to around 13.4 - 13.6v?
2. I'm running a Plasmatronics PR1210 regulator off the 50watt (2.4amps max) panel with a boost max of 14.6v. it would seem this regulator is perfect for the fullriver batt, providing a fast charge. The site I'm looking at (www.energymatters.com.au) suggests the PR120L for sealed lead acid batteries which actually has a lower boost max 14.2v, so I'm not convinced. Do I have the right solar regulator?
3. I had always run a negative strap to an unpainted part of the body in the rear of the ute, seemd to work fine on the N70. Should I be running a cable back to the main batt neg. , just to be sure?
4. What is the minimum cable size I should be running from the battery to the fridge inlet (about 2m)?
5. What is the minimum cable size I should be running from the redarc under the bonnet to the aux batt (about 5m)?
6. How do I measure the voltage input (on panel or redarc) with a multimeter whilst it's charging? The instructions on my cheap Dick Smith multimeter arent real clear.
7. Can I run the solar panel and the redarc AND draw off the battery all at the same time? (e.g driving with the solar panel attached to the roof)
7a. Should I install a reverse blocking diode on the panel side if I do no.7 ? (then I could leave it attached 24/7 without trickle back overnight?)
Thanks again for all your help!
Ramjet
PR1210
boost max 14.6v
Boost cutin 12.5v
Float max 14v
Float cutin 13.4v
PR1210L
boost max 14.2v
Boost cutin 12.5v
Float max 14v
Float cutin 13.4v
