Dirty fuel?
Submitted: Saturday, Aug 07, 2010 at 20:38
andyq
I have a 2001 nm Pajero with a problem. i have just returned from a trip to
Alice Springs from
Adelaide, since then the Paj chugs a bit when i take off or when i put my foot down to overtake, it idle's fine and cruses ok. i have heard the
fuel from some of these
servo's along the stuart highway can be a bit sus, could the
fuel filter need replacing or is it much worse?
Reply By: Member - Ian H (NSW) - Saturday, Aug 07, 2010 at 20:55
Start with the simple things like
fuel filter.
426544
Follow Up By: miandering fiander - Saturday, Aug 07, 2010 at 21:03
The filter is an easy thing to fix first, but I would wait till you had nearly no
fuel left and refuel after fitting the new filter.
697113
Reply By: miandering fiander - Saturday, Aug 07, 2010 at 20:59
I run a dual
fuel filter system in the Prado.
I run through a CAV filter first then into the Toyota one.
The CAV filter has a clear glass bottom so you can see if you have a problem and I carry a spare just incase.
They only cost about $7.00 for the filter after the initial set up of aprox $100.00
426545
Reply By: Eric Experience - Saturday, Aug 07, 2010 at 21:14
Andy.
The symptoms you describe are not consistent with bad
fuel, the most likely thing is a crack in the plastic insulator around a spark plug, if you pull out the leads one at a time and look very closely at the sides of the insulator you will find a black mark where the spark is breaking through. Eric.
426546
Follow Up By: dbish - Saturday, Aug 07, 2010 at 21:32
Asuming its a V6 petrol Pajero I would go with Erics advice, its a common fault with engines with sparkpugs in the center of the cylinder head. V6 mazdas have simillar problems & will slowly get worse untill it misses at idle, & the spark punch through will be just a pinprick size black dot on the insulator boot. Daryl
697115
Follow Up By: andyq - Saturday, Aug 07, 2010 at 21:43
Yes i forgot to mention, it is a V6 petrol engine
697117
Reply By: Joe Grace Doomadgee - Saturday, Aug 07, 2010 at 22:42
a note on dirty fuel.............
If when you pull up at a
servo and there truck is there filling the tanks, drive on to the next one, it stirs up all the dirt and
water ect in the bottom and you get a
tank full of cruds....
426562
Reply By: Member - Bucky - Sunday, Aug 08, 2010 at 05:00
andyq
Dirty fuel can be picked up anywhere.
One thing you can do with petrol engines, or should I say, used to be able to do to them, is to put in 2 or 3 lts of Metho. Apparently it can soak up to 3-4 times its own weight of
water contaminates
I also like the fact that someone has said to run your vehicle almost out of fuel before you top it up again , and change the filters.
If you are slightly mechanical, or have a couple of mates that are, another thing you may
well consider is dropping oout the fuel
tank, and give it a good clean out.
Put it all back together, with new filters.
An inspection point is to remove the sender unit/inspection port from the
tank, and have a look inside ( with a torch, and a mirror ) to see if the
tank has crud on the bottom.
Hope this helps
Bucky
426578
