Reversing Camera on a Winnebago
Submitted: Tuesday, Aug 10, 2010 at 18:36
ThreadID: 80640 Views:3777 Replies:2 FollowUps:0
Hi All, About to install a reversing camera in a Winnebago Leisuer Seeker and was wondering if anyone else has done this lately. My initial thought is to drill through the wall into the rear cupboard and run the camera cable through the side cupboards to the front. Any other thought would be appreciated, cheers. Ian
Reply By: Member - DickyBeach - Tuesday, Aug 10, 2010 at 18:41
Bluetooth?
AnswerID: 426862
Reply By: Member - Graham H (QLD) - Wednesday, Aug 11, 2010 at 13:50
I have recently done this on a 25ft van
I drilled through the rear behind the mirror and dropped the wires down to the bottom and pulled them thru a small hole drilled in the fibreglass shell on the rear.
I then bought a couple of lengths of conduit and ran it thru that up to the rear of the A frame and pulled it through to the hitch.
Wireless is unsatisfactory as is a rear vision mirror screen
I have tried all combinations and have settled on a wired setup with a separate screen
In your case if you can get it all the way thru the cupboards it would be far better than an unwired system.
AnswerID: 426945
