Hilux question???
Submitted: Thursday, Aug 12, 2010 at 21:20
Member - Christopher P (NSW)
Hi Everyone, your friendly pain in the rear is here!!!
Just a quick question to the hilux lovers, will a later model >1996 leaf sprung power steering pump, steeriing box, bolt straight onto a 82 hilux leaf sprung, being of the L motor config, theory says yes, my exprience says maybe???
the motor in my 82 has being changed to a 2Lfrom an L.
it's so my wife can drive my beast????
Reply By: trainslux - Friday, Aug 13, 2010 at 09:30
I dont think so, as I do know that the early diesels had a different length
water pump, so if you got the later one, the belts didnt line up.
No idea on the bolt locating holes, but I rekon you would run into issues with belt alignment.
Try outerlimits, much younger crowd there who modify their vehicles.
Trains
427100
Follow Up By: Member - Christopher P (NSW) - Friday, Aug 13, 2010 at 09:57
shouldn't be an issue ai it has the 2.4L diesel in it. But will double check that when i get a chance??? Thank you for the info???
697707
Follow Up By: trainslux - Friday, Aug 13, 2010 at 14:56
Ahh, just re read your post and missed that before.
If you can get the power steer from a 2.4 model, I do not know if the actual steering box uses the same mounts, but would assume that it does.
The rest should be an easy swap.
T
697732
Follow Up By: Member - Christopher P (NSW) - Friday, Aug 13, 2010 at 15:14
Thanks mate yes it looks like an easy swap, mounts up the same, i think it is a 2.4L. checked out before. it does look easy. i need to get the reservoir no and flexi hoses. I only do stuff when i have everything with me!!!!
Thanks for your help, much appreciated
697733
