Mitsubishi Canter 4x4
Submitted: Friday, Aug 13, 2010 at 14:59
ThreadID: 80685 Views:26981 Replies:10 FollowUps:16
Re this now archived past thread ID 4722 by "bloffy", submitted: Sunday, May 04, 2003
"I'm thinking of buying a Mitsubishi Canter 4x4 crew cab to convert into a slide-on style camper. I have a wife and two dirt magnets and have just returned from a year-long around-Oz trip so I have some definite ideas I want to put into action. If anyone has had any experience with these vehicles (or similar), your views would be appreciated. How do they handle? What are they like off-road? On-road? Any camper ideas? This will be a long-term road rig for all sorts of on and off-road adventures."
bloffy, if you are still around did you get one? and if so how has it performed. I'm in the situation where my Troopy has been wiped out so I'm in the market for another 4x4.
Rod W
Reply By: roberttbruce - Friday, Aug 13, 2010 at 16:14
I saw a 99' single-cab with streamline fibre-glass rear camper and only a 24inch pop-top roof... was in brisbane about 10 months ago... Turbo diesel - motor fuel pump good, after-market long-travel suspension and rigged for extended remote stays...
it looked really good because unpoped the rear was streamline and flush with the front cab
layout was well thought, had a walk through cabin and complianced for 4. The two rear seats where just behind the driver and rotated to face a dining table so then it could be used to dine four or sleep two. main bed was across the back.
needed a little tlc, 29K... was super-cheap i thought, just the suspension and truck would have been worth that much, better yet the rear...
it went out west and about three months later re-appeared on TP in wa for 65K.
It lasted less than a week, that was prolly its true value...
good-luck with your build, the year you've spent out will hold you in excellent stead for the task... 1000L water-tanks anyone...lol
AnswerID: 427134
Follow Up By: Rod W - Friday, Aug 13, 2010 at 16:32
Hey Bob,
I'm just doing a follow up on the bloke "bloffy" to see if he brought one etc.
FollowupID: 697738
Follow Up By: roberttbruce - Friday, Aug 13, 2010 at 20:47
this one here?
http://www.tradingpost.com.au/Automotive/Trucks-Buses/Trucks-Buses/AdNumber=TP003363574?BackToResult=true&AdOnTop
FollowupID: 697770
Reply By: Member - DickyBeach - Friday, Aug 13, 2010 at 16:43
Rod,
The EarthCruiser guys are using a Canter platform so that might give you some confidence. See www.earthcruiser.com.au
DB
AnswerID: 427135
Reply By: Bandicoot - Friday, Aug 13, 2010 at 19:28
We bought an EarthCruiser; took delivery in March. It's the SWB (110 inch) motorhome version. Our plan is to take it overseas; hope to be away about 6 years in total. Tare 4.9 t, GVM 4.5 t with GCM 8 t. Has been going great (brilliantly actually to date) and done 15 k now. It comes standard with the long travel ("hard road soft ride") suspension (150 mm longer leaf springs front and rear and relocated hangers and different shockies front and rear). We also got the Stratos LTSS replacement seats. We run the Michelin 255-100 R16 XZL "super singles" at a bit lower pressure than EarthCruiser recommend, but overall are getting a good ride. Still truck like, but overall quite acceptable and in fact, better than any of our previous 4x4's on corrugations.
Bandicoot
If you come to a fork in the road, take it
AnswerID: 427149
Follow Up By: roberttbruce - Friday, Aug 13, 2010 at 20:45
hi BC, these are a great vehicle, congrats.... anychance of hearing a a-round-about-price?
FollowupID: 697769
Follow Up By: Bandicoot - Saturday, Aug 14, 2010 at 14:31
Price will depend on your level of options: fuel tanks, water tanks, bullbar, seats, centre console, roof rack, winch, etc. Ours was around $200k, about the same as our previous off-road caravan and 4x4 wagon, but this machine can go anywhere. Not cheap but everything on it runs from diesel: 5 litre turbo intercooled 4 cyl diesel engine, diesel cooktop, diesel hot water system (inside and outside shower), diesel interior heating etc. All stainless steel fittings, 1800 W pure sine inverter, solar, plenty of Fullrivers on board, etc. Electric roof, electric awning, electric steps. Not a hitch so far. The photo in the Avatar is Goog's track. It's great on sand and that's from someone who has done the Simpson 4 times, the Cape 8 times, CSR , Kimberleys, etc. It's my pre-retirement mid-life crisis! But our main purpose is we plan to spend around 6 years going right around the world and this is the ideal vehicle for it. Fits into a 20 ft shipping container! Parks in a standard car park, but has everything you need for independent travel.
FollowupID: 697837
Follow Up By: Roach"ee" - Saturday, Aug 14, 2010 at 15:26
Bandicoot, could I ask you to clarify the weights you mentioned please? If the Tare is 4.9t, then I would have expected the GVM to be something above that figure, not below??? I can understand the GCM being listed @ 8t.
Correct me if I'm wrong, but my understanding is that Tare weight is the bare weight of the vehicle (ie: with no fuel and nothing loaded).
The GVM is the maximum weight you are permitted to have on the 4 wheels of the vehicle (ie: the sum of the Tare and the "payload" permissable). I would have expected the GVM to be at least 1t to 2t (or thereabouts) higher than the Tare.
The GCM is the maximum permitted weight of the whole rig, assuming you might be towing a trailer/caravan etc. So, @ 8t, the maximum permissable towing capacity is the difference between the GVM and GCM.
However, the vehicle would also have a maximum towing limit and it may be possible to be within the GCM but still be illegal because you have a heavier-than-permitted trailer on the back. This can happen with Patrols, Cruisers etc.
As I said, I will stand corrected on anything I have said here; it's just my understanding and I am somewhat confused by the figures you have mentioned.
FollowupID: 697839
Follow Up By: Member - Ian M (QLD) - Saturday, Aug 14, 2010 at 17:41
Bandicoot
I had been thiking of an Earthcruiser but decided to wait a year or so to make sure the operation got off the ground. The year is up and I am now seriously looking.
Did you also look at the All Terrain Warrior (which has some similarities) and the SLR Adventurer (which is not a pop top though so no good for containerisation). The SLR is Isuzu NPR 300 based - and it seems a little better spec'd for long distance driving (with a susension mod, super singles and Stratos seats like the EC). All three are big dollars and it isn't easy to find out objective "user reports".
Thanks in advance for any more info you can provide.
IAN
FollowupID: 697846
Follow Up By: Bandicoot - Sunday, Aug 15, 2010 at 07:38
Roach "ee"
Sorry. That was a typo. Tare is 3.9 tonnes not 4.9 tonnes! GVM is correct at 4.5 tonnes.
The Canter is engineered to be a 6 tonne GVM, 9.2 tonne GCM vehicle. Original tare (for the cab chassis) as purchased from Fuso is 2610 kg.
However, it can be purchased "placaded" at 4.5 tonne GVM/ 8.0 tonne GCM for a number of reasons:
* Allows driving on ordinary car licence
* Cheaper rego
* No annual mechanical roadworthy before re-registration
The vehicle has identical mechanicals, brakes, etc irrespective of whether you buy it as the 4.5 t GVM or 6 t GVM version.
If you plan to take a vehicle overseas for an extended period, it's very important for it to be under 4.5 tonne GVM otherwise when you come to re-register it (while the vehicle is overseas), you have to ship it back to Australia for a roadworthy. And you won't be able to take a vehicle across an international border unless you can prove it is still registered in the country of origin. It's critical is also remains registered for insurance purposes and also to keep your Carnets valid.
Bandicoot
FollowupID: 697880
Follow Up By: Bandicoot - Sunday, Aug 15, 2010 at 08:05
Ian M
I did look very seriously at both the ATM and Amesz. When i was doing my research, I didn't come across the SLR although I have been aware of its existing for probably the last 9 months.
There are a range of factors to consider. These were the most important to us (but other factors will no doubt be more important to others):
* Are you planning to take the vehicle overseas. It's cheap to ship a vehicle o/s providing you can fit it into a shipping container. This rules out anything that hasn't got a pop-top. There are other crticial reasons why vehicles have to go into shipping containers, e.g. security of the vehicle and all its contents.
* Weight: some construction methods are lighter than others and if you need to get under 4.5 tonnes (see above post) then probably anything steel-frame will be ruled out. In addition, non-pop-tops tend to have "overhead" cupboards, which are nice to have, but also add to weight.
* Cost: "custom builds" tend to end up more expensive as it's harder to get a firm price plus by definition, some of the engineering for "your" vehicle will be paid for by you alone, and not shared around. EC is not a custom-build. There are options, but apart from that, every EC (including every floor plan etc) is identical.
* Fuel source: we particularly wanted the vehicle to run solely on diesel, including diesel hot water system, diesel cooktop, diesel interior heating, and definately no LPG
* Where manufactured: We live in Brisbane which is where EC is manufacturered, so I was more confident about getting what is one of the first production units back to them for any warranty work, if needed
* Manufacture method: EC is the only one (as far as I'm aware) to be manufactured under the Federal Govt DOTARS "2nd stage manufacturing process". Traditionally motorhomes (or refrigerated vans or other “custom builds”) in Australia are created by the manufacturer first buying a cab-chassis or other “base vehicle” which is then registered (giving it licence plates and allowing it to be legally driven on the roads). The base vehicle as sold is already compliance-plated by the importer or manufacturer to prove that it meets all the Australian Design Rules (ADR) relevant to the vehicle. The base vehicle is then modified by the body-builder, certified by an engineer (e.g. for different number of seats) and then is approved by the State Government for registration in that State. It is given a new State compliance plate fitted that says it can legally be registered in that State because vehicle registration is state-based in Australia. If a person moves interstate, or the vehicle is sold interstate, then it will have to be re-registered in that new State, and this will require new inspections in that State, which will be to the guidelines applicable at the time in that State. In some cases, other States have refused to register a vehicle because it would fail to meet the different design standards of that State at that time.
Compare this to the process used by the high-volume car manufacturers. A new model of car (e.g. an import) is brought to Australia and then tested and found to meet the ADR and is then compliance-plated. All states will automatically then register that vehicle, whether new or second hand. This approval process is a federal one, not a State process. Once certified as being compliant, it never needs to be re-certified, even if the owner moves interstate.
As an example, Queensland will not allow a Fuso Canter in the 4500 kg GVM class (which is sold by Fuso with dual rear wheels) to be fitted with single rear wheels but NSW will allow this. However, if a 4.5 tonne GVM vehicle is approved federally with super single wheels (even if manufactured in Queensland), then it will automatically be registrable in ALL States including Queensland!!! How's that for "Yes, Minister"!
As I understand it, this is the reason the EarthCruiser has not gone down the normal motorhome build route. By going through the Federal process using the SMM approvals system, all EarthCruisers are then automatically registrable in Australia, and that will also help with overseas exports of EarthCruisers. They are currently preparing to send the first one to the USA.
Bandicoot
I'll post the specs on our EarthCruiser and you can check them out.
FollowupID: 697882
Follow Up By: Roach"ee" - Monday, Aug 16, 2010 at 12:54
Thanks for the clarification Bandicoot, but I must say that I'm still a bit confused to a certain extent. If the tare is 3900kg and the GVM is 4500kg then you only have an effective payload of 600kg.....about the same as a Nissan patrol.
I would have thought it would have enjoyed quite a bit higher margin as once you add 2 people (say 180kg), then start adding clothes, crockery, food, bedding, maybe a gennie(?) etc etc, you would quite quickly overshoot the 600kg payload. This is one of my concerns about the "normal" 4x4 vehicles; their distinct lack of realistic payload.
Insurance issues as well as legalities are the obvious issues.
FollowupID: 698040
Follow Up By: Bandicoot - Monday, Aug 16, 2010 at 20:07
Roach "ee"
I guess you could say that the Canter has a tare of 2.6 t and GVM of 4.5 t so that's a payload of 1.9 tonnes.
The reality is that the 1.9 tonnes is taken up with the motorhome (camper), which includes basically everything you need to go away on an expedition. The only things you need to add to the 3.9 "tare" is water and fuel (it already has all the tanks and plumbing), 2 persons, clothes and groceries and a couple of camp chairs and few other minor things.
The only way to get more "payload" than 600 kg and stay under the 4.5 tonnes, would be for the original cab chassis tare to be even less than 2.6 t but this isn't very practical given the tough chassis etc.
The other thing to note is that the vehicle is engineered to 6 tonnes GVM and 9.2 tonnes GCM, so it is very much "understressed" at 4.5 t which should result in good reliability as everything on the vehicle is designed for a much larger payload: chassis, suspension, brakes, diffs, axles and housings, transmission, etc. This is in contrast to (say) a L/C which, when "overloaded" at more than its GVM, is actually over the manufacturer's stated "safe" load rating. This is not the case with the EC.
The main market for the Canter 4WDs is the bush fire brigade, followed by mining companies and then farmers.
The other side of the coin is that the more payload you have, the more you are tempted to carry that "extra" gadget or supplies. I agree that not having enough payload is a problem, but sometimes have too much surplus payload can also be a problem! I'm pretty confident we'll be able to keep at 4.5 t or very close to that.
Bandicoot
FollowupID: 698083
Reply By: Eric Experience - Friday, Aug 13, 2010 at 21:05
Rod.
The Canter is a great vehicle, You cannot drive fast on rough roads but at the end of the day you travel further in a day because you start early with no set up time. One thing I recommend is to make a sound proof cover over the gear box. Allow for it in the design because the gear noise can be annoying. Eric.
AnswerID: 427162
Reply By: Rod W - Friday, Aug 13, 2010 at 21:38
Thanks for your replies fella's. The Earthcruiser is a bit proper flash for me and probably the dollars too. And there's no doubt that the Fuso is tough and durable.
Since I place this post this arvo I have researched for the specs on the Fuso which indicates they run out of puff at 102ks per hour, which okay you don't need and or do that on a bush track but on the open road it would be panting a bit. Then there's the issue of it being a box and with the overgrown tracks that I have a tendency to explore it would get well and truly roughed up. My more or less now dead Troopy (motor vehicle accident - not my fault) is testament to traversing overgrown tracks.
AnswerID: 427168
Follow Up By: get outmore - Saturday, Aug 14, 2010 at 21:31
Rod im not sure if you ever saw a pic of my old 75 camper but that would be more or less the same hight and width as a canter camper
- absalutly not suitable for you
it really restricted where i could drive it and it wasnt till the 80 i could get to where i wanted
vehicles like that seem like a good idea but ultimatly are only good for dirt road driving or the beach
my camper - completly unsuitable for bush driving due to size
the fire engine :-(
FollowupID: 697867
Follow Up By: Bandicoot - Sunday, Aug 15, 2010 at 08:12
Rod W
With the super single wheels, the EarthCruiser tops out at 127 kph (3100 rpm).
It's very comfortable cruising at 100 kph and I've run it at 110 kph.
100 kph is 2400 rpm. Cruisy!
Remember the super single tyres are almost 37 inch dia, much bigger than normal 4x4 tyres so this effectively adds to the "height" of the gear ratios.
Bandicoot
FollowupID: 697883
Follow Up By: Rod W - Sunday, Aug 15, 2010 at 22:26
G'day Get outmore (Dave),
Yep I remember seeing pictures of your 75 Camper, like you say totally unsuitable for overgrown/little used bush tracks that we like and traverse here in WA.
In the meantime the fire engine has been killed and not by me. It has/had been an absolutely fantastic vehicle.
FollowupID: 698000
Reply By: The Landy - Friday, Aug 13, 2010 at 22:45
A coach-builder in WA is usiing Canters as a platform. Saw a unit on our recent travels and looked pretty good. Can't remember the name, but I'm sure someone will now it??
Cheers, The Landy
AnswerID: 427182
Follow Up By: Member - Joe F (WA) - Saturday, Aug 14, 2010 at 02:49
G'day everyone
Rod W, the Canter 4WD is a Truck ~ it drives like one no matter what, they are rough on and off road, yes you can spend heaps of money buying and then modifying one, but at the end of the day it's a truck.
They are quite noisy and the cab is definately not designed with the driver in mind, it is not ergonomic and if you are anywhere around six feet tall, you may end up dreading having to drive it ~ for any length of time.
I drive a variety of vehicles and the Canter 4wd is not my idea of a good vehicle to operate. There are plenty of them around in the Pilbara, but they are mainly used as "man hauls" in the mining industry.
Image Could Not Be Found
The Coach body on this Canter is something else again and it would make a genuinely good camper/motor home ~ yes even I like to dream.
FollowupID: 697791
Reply By: Bandicoot - Sunday, Aug 15, 2010 at 08:27
Get Outmore
I can't agree about the Canter being much less manouverable than a L/C.
I've done quite a number of very tight tracks now and overall it's a minor issue.
The Canter acutally has a better turning circle than the L/C and much, much better approach, departure and rampover angles. A L/C has a GVM of 3.3 t whereas the EC is 4.5 t (6.0 t if off-road). That also counts for a lot as, in practice, most "expeditioners" end up towing a camper trailer, which also reduces flexibility, an issue you don't have with an EC.
Here's my "take" on the situation, Canter versus a L/C 200 series wagon (I accept you have a troopie which will be different to below, but I never collected the data on a Troopie).
• EC Length with bullbar and with rear spare tyres: 5.91 m; with bullbar and without rear spares: 5.80 m. [L/C 200 series wagon 4.95 m without bullbar or rear spare wheel. Most serious L/C are going to put on a bullbar and rear-mounted spare, so the lengths will end up about the same]
• EC Width (excl external mirrors): 2.08 m, with external mirrors folded in: 2.26 m, with mirrors out: 2.36 m [L/C 200 series wagon 1.97 m incl mirrors]
• EC Height: 2.52 m. Height with optional scrub bar and top basket 2.56 m. Height with roof up: 3.16 m. [L/C 200 series wagon 1.905 m WITHOUT roofrack]
• EC Wheel base: 2.86 m [L/C 200 series wagon 2.85 m]
• EC Track (front and rear): 1.75 m [L/C 200 series wagon 1.64 m]
• EC Ground clearance: 0.265 m [L/C 200 series wagon 0.22 m]
• EC Approach angle (without bullbar) : 45deg [L/C 200 series wagon 30deg]
• EC Departure angle (with rear spare tyres): 40deg [L/C 200 series wagon 20deg]
• EC Ramp over angle: 30deg [L/C 200 series wagon 25 deg]
• EC Turning circle (kerb to kerb): 11.4 m [L/C 200 series wagon 11.8 m kerb to kerb]
• EC Wading depth (to camper and cabin floors): 1.12 m (expedition loading)
• EC Tare weight (with standard EarthCruiser options): 3900 kg excluding fuel and persons. [L/C 200 series wagon 2700 kg approx]
• EC GVM: 4500 kg [on-road], 6000 kg [off-road] [L/C 200 series wagon 3300 kg]
AnswerID: 427263
Follow Up By: get outmore - Sunday, Aug 15, 2010 at 20:46
I made those comments from experience with going bush with rod
i would not take a 200 series where he likes to go either
the pop top on the Ec certainly is a great idea but even with that as i said 2.5 m is way to high for bush tracks and a width of over 2m is too wide especially as the widht remains constant with hight instead of tapering in.
i have no qustion they are a good vehicle that suits many peoples needs but from knowing what rod does I doubt it
that cruiser in the pics has simular dimensions to the earth cruiser and certainly that was far too large
it was great for many things but the stress of wiping it out down even mildly overgrown tracks and often having to turn back made me change my mind about larger vehicles
FollowupID: 697980
Reply By: balko - Sunday, Aug 15, 2010 at 19:36
Just took my canter across the simpson has super singles and modified suspension. It went every where the hiluxs went even up big red. Plus mine had to carry all the gear for 5 bike riders Cheers Tony If your in Sydney you can test drive mine any time
AnswerID: 427325
Reply By: Roach"ee" - Tuesday, Aug 17, 2010 at 20:50
I've just been searching the net with a renewed interest in this type of vehicle and found my ideal rig......
http://www.truckhub.com.au/DesktopDefault.aspx?ItemID=3224291&TabID=3443
I've only got 2 things stopping me from catching a plane to Qld to look this rig over....
1). and handbrake here that is firmly stuck in the STOP position
2). lack of ready cash....anybody want to buy my Chev 6.5 dual cab for a lazy $40K??? hahahaha
AnswerID: 427512
Reply By: Robin Miller - Tuesday, Aug 17, 2010 at 22:04
Been meaning to ask Rod.
What are key issues that would make you re-consider another car over the troppy - perhaps the accident/saftey?
Certainly as I try and work thru what is next rig for my use I find it hard , as you can come up with several senarios each of which has a different answer - then you (I) think well maybe just the same thing but a little better everywhere then you (I) find it doesn't really exist and so head back to the beast we know !
AnswerID: 427523
Follow Up By: Rod W - Wednesday, Aug 18, 2010 at 21:35
Robin,
The accident has certainly made me aware of how vulnerable the Troopy is, with just a simple laying it over on its side and it becomes a right-off, but then the body is just a big empty shell so to speak.
Before the Troopy I had a 1972 Toyota Dyna Twin Cab (1.5 ton job) to which I converted into a 4x4. It, like the Troopy was narrow and fitted better down the overgrown tracks (which do give vehicles a hard time with branches constantly bashing against the window pillars and marking the paintwork all over both sides) constant that I like to traverse in the Yilgarn region here in WA.
Thinking of the Dyna got me thinking about the Canters and a cab/chassis job and I build a box on the back to suit my requirements and the dollars as well. But in looking into the dimensions of the Canters cabin it would well and truly take a hammering from the bush, so I've decided against the Canter.
Like you say Robin I'll be heading back to the beast I know but a bit different from the 4.5lt petrol straight 6 engine to the 4.5lt V8 diesel engine.
FollowupID: 698306
