Nissan D22 Engine
Submitted: Saturday, Aug 14, 2010 at 11:57
dfg
I have owned a D22 ST-R for 5 years and the 3 litre engine hasn't missed a beat - been to Simpson and back and many other
places.
I'm thinking of upgrading to the new D22 - anyone got any comments or feedback on the 2.5 litre engine now fitted? Is it as reliable as the old one?
thanks
Dave G
Reply By: nowimnumberone - Saturday, Aug 14, 2010 at 13:18
one thing ive noticed quite a bit is front brakes and rotors wear out at around 40000ks.the ones ive changed are all tradies utes.funny thing is local nissan dealer charges around $800 to do front brakes and dont use genuine parts we use the same parts from same supplier and charge around $300.local nissan service guy says there having problems with leaking injectors caused by running such high pressure.and theres a rubber boot around the gear shift that splits allowing noise ans smell in.ive changed a few drive shaft boots there more like plastic than rubber so the crack easy.but people love the power of them
427212
Follow Up By: Patrol22 - Sunday, Aug 15, 2010 at 17:41
Really!!!!! The 'high' pressures run in this engine are no different to other common rail engines ....20-30,000psi and they are fitted with piezo injectors that work a treat from my experience and I now have 46000km on my 2.5 crdi albeit it is fitted to my D40 Navara.
I agree the brake thing but the wear rate is directly proportional to the weight carried and the propensity for the driver to over-use the right boot. While I've already bought a set of DBA slotted rotors and Bendix pads to fit to
mine I still have approximately 5mm of wear before I'll do the change. BTW this pad/rotor wear nexus is a feature of Euro 5 build standards and is common across all vehicles that have a high presence in the European market....eg Mercs, VW, BMW etc.
697955
Reply By: Butch58 - Saturday, Aug 14, 2010 at 13:32
HI dfg,
I had a STR D22.... 3 Ltr for 3 years before upgrading to STR D22..2.5 Ltr 12 months ago.
I'm more than happy with the new 2.5 motor........prefer it to 3 Ltr .......just as much power and torque as 3 Ltr........less turbo lag .......better
fuel economy .......no problems so far.
This is the same motor as D 40 but de-tuned with different turbo and manifolds....should last a bit longer than D40 motor as it is not being flogged to reach max power and torque. cheers Butch
427215
Reply By: dfg - Saturday, Aug 14, 2010 at 14:18
Thanks guys - I just wonder how far they can push these little engines before they shorten their life.
Dave G
427217
Follow Up By: Nutta - Saturday, Aug 14, 2010 at 21:44
Well, Mitsubishi are now running 2.5l and landrover have run them for years with out dramas (not including some electrics). I've been watching the nissans for a while and besides clutches and brakes they seem to be holding out ok.
697869
Follow Up By: feraldisco2 - Sunday, Aug 15, 2010 at 16:34
despite his name, Nutta is on the money. It's quite possible to get 500K k out of a 2.5TD. The newer technology is just highlighting how inefficient old TDs were. I must admit that something like a Nissan TD42 provides a bit more peace of mind as there's less to go wrong, but for that comfort of avoiding a rare problem, you'll have to put up with sluggish performance and poor
fuel economy every day...
697943
