Pajero on the Canning Stock Route
Submitted: Sunday, Aug 15, 2010 at 11:06
ThreadID: 80718 Views:7164 Replies:4 FollowUps:8
This Pajero came to a halt on the Canning Stock Route and over the past 3 years I have taken photos of its condition.
It is located on top of a dune and from what I have found out it was being recovered after the clutch had gone. It was towed here to move it off the main track in a safer position.
Over the years the vehicle has been vandalised. Any thing that was any good has been taken, what is left has been destroyed and now the vehicle is being used as a rubbish bin.
Image Could Not Be Found
The Pajero has joined the other 3 vehicle that are still on the track.
The question now is what should happen to the vehicles?
Left as a reminder of what can happen
or cut up and removed.
Wayne
Reply By: Member - Joe F (WA) - Sunday, Aug 15, 2010 at 11:57
G'day Wayne
It just goes to prove the point of how under prepared some people are when travelling in what is a very remote part of Western Australia, I'm not saying the vehicles did not have all "the toys" on board. No doubt there were catastrophic circumstances causing the breakdown(s) but then just abandon a vehicle and seemingly no responsibility in recovering it or what's left of it.
I don't think it should be a historic marker or even a suitable reminder for future Canning travellers it is outright illegal dumping and it magnifies the huge foot print being stamped in the outback and on the Western Desert regions of W.A.
You also say the Pajero is being used as a rubbish bin now !!
Shame on the filthy mongrels who are adding to Cancer of the outback.
I am sure the owners of these "illegally dumped" vehicles can be tracked down ~ fined for dumping and made to pay for the recovery and removal of the things ~ little wonder that the Martu people are trying very hard to close all access to the region.
AnswerID: 427287
Follow Up By: Member - Marc Luther B (WA) - Tuesday, Aug 17, 2010 at 23:51
Hi Joe
Although we live in Mulan, near Lake Gregory (Paruku), my wife is a full blood aboriginal woman. Her mother is one of the oldest living Martu people, and they are nbot trying to close the region for the rason that you have mentioned. It is because of the disrespect being shown to some areas that should not be traversed by non-lore people.
We have been through the area on numerous occasions, and removed a lot more rubbish than what you see there normally. It is obvious that when people cannot be seen, they care a lot less, but that luckily is only a minority.
Marc
Why travel overseas, you could travel Australia your entire life, and not see it all.
FollowupID: 698237
Reply By: Motherhen - Sunday, Aug 15, 2010 at 12:15
Hi Wayne
Theoretically, they should be removed; likewise the hundred of car wrecks that dot the landscape around remote and inland roads such and the Great Central Road.
Vehicles are generally abandoned because the cost of recovery far exceeds the value of the vehicles, and such costs may be beyond the means of the unlucky traveller. Sad to see someone's dream destroyed by a simple mechanical failure, which despite the best of preparations can happen to any of us.
What would you do if it was your vehicle?
AnswerID: 427290
Follow Up By: Wayne (NSW) - Sunday, Aug 15, 2010 at 13:04
Motherhen,
Good point about what if it was my vehicle or a vehicle in a convey that I was leading.
Planning, preparation and experience have got me through in the past and hopefully in the future.
Apart from the Pajero, the other 3 vehicles on the CSR were burnt as a result of spinifex build up causing a fire.
Planning to check under the vehicle after driving through spinifex grass, the taller the grass the more often the need to check and vehicles with under body protection are more at risk.
Having a wire hook and a spray bottle filled with soapy water in case of build up.
Having detergent mixed with water in the spray bottle acts as a wetting agent.
The Pajero had a burnt out clutch, that would be driver error.
Having the vehicle removed from the CSR would be a project that would require a lot of planning and expense.
The vehicles would be too hard to remove in one piece but if they were cut and placed on trailer, to keep the weight down, then it would be possible.
Who would do this and who would pay for it would be harder to organize.
Wayne
FollowupID: 697919
Follow Up By: Member - mazcan - Sunday, Aug 15, 2010 at 21:49
hi motherhen
you are correct
3 were spinifex fires and the other was a crutch failure
there has been a drum muster in the past and so why not a vehicle muster but the logistics is much harder for the wrecks
drums pack on a lot easier
FollowupID: 697993
Follow Up By: Joe Grace Doomadgee - Sunday, Aug 15, 2010 at 22:08
it all is interesting to look at and judge but if we sit back and say that all this must be cleaned up and moved, exactly why is it, is it because it looks bad, it is in the road of "something", not "safe", if we move it from one location to another we have not solved the problem, just re-located it, if "environmental" is the reason then what a HUGH waste of fuel it would be to move them .....
Go and live out there for a few years, live on one of the communitys, even driving up to them you notice the rubbish gets worse the closer you get..... the car bodies on the side of the road increase ....
The BIGGEST mistake we as "outsiders" have made was to turn up, try to "save" the communitys and start all these big clean-ups, now we have this awful culture of them leaving rubbish everyware as it gets all cleaned up by us suckers, in these communitys the ratio of services and "outside help" per person is far greater than citys as we seem to send in the "do-gooders" that think they will save the world and just make it far worse, watch all the promises over the next few weeks just for votes .....
The answer ??? i really dont know, education is all that is left that will work.
FollowupID: 697998
Reply By: Alloy c/t - Sunday, Aug 15, 2010 at 12:39
Stripped of all the useable bits before a repair can be effected ,, Late 70s had a Ford Fairlane with a windsor v8 donk , one friday night on the way from Bris to Southport had a flat tire just after the turnoff to Labradore , spare flat as well , caught a lift to Southport and raised my brother , cut long story short , was gone from the vehicle for less than 3 hrs , was stripped of the MOTOR by the time Igot back to the car , what do you do !!
AnswerID: 427291
Follow Up By: racinrob - Friday, Aug 20, 2010 at 19:37
A couple of years back I saw a caravan on the side of the Gibb River Road with a broken spring or something. The owner had left a big sign saying, "Please don't touch our van, we've gone for parts". I don't know how long it had been there but it had been stripped almost bare.
Rob.
FollowupID: 698564
Reply By: Robin Miller - Sunday, Aug 15, 2010 at 14:09
The vehicles should be left there , thats less than 1 wreck each 500km , and they serve to make people a little more cautious.
I wonder where would the Canning be if we removed all trace of the now unnecessary 51 wells.
AnswerID: 427295
Follow Up By: Motherhen - Sunday, Aug 15, 2010 at 15:22
Great Central Road has something like 100 wrecks in 100 km stretch, and on a road where removal of wrecks would be more practical than on the CSR.
Mh
FollowupID: 697934
Follow Up By: Flynnie - Sunday, Aug 15, 2010 at 15:39
Agree with Robin & Motherhen
If someone wants to clean up all wrecks there are much more accessible wrecks along the Tanami Road and numerous other places that should keep people busy for years to come.
Just an observation from last month on the CSR. It appears all the wrecks on the Canning were once petrol engined vehicles.
Another point of note is that most travellers pick up what rubbish is there. Some of this seems to accidentally fall off vehicles, some is deliberately dumped. Unfortunately as one approaches the more populated parts the amount of rubbish increases dramatically. Also the well 23 fuel dump seems to collect an awful lot of rubbish.
Flynnie
FollowupID: 697937
Follow Up By: Member - Bucky - Monday, Aug 16, 2010 at 03:26
Gr8 call Robin
FollowupID: 698006
