Water Tank Recommendation...What do you use ????
Submitted: Monday, Aug 16, 2010 at 22:09
skmaint
Just wondering if anyone knows what is a good quality
water tank around the 80ltrs + for my camper trailer. Needs to be strong (still fitting a bash plate over it) and not have to bi carb it out all the time to get rid of the plastic taste.
Would prefer a brand that can be purchased in
Perth or surrounding areas.
Your input would be greatly appreciated...
Simon.
Reply By: Member - Duncs - Monday, Aug 16, 2010 at 22:54
Simon,
I have used plastick jerry cans for 14 years and never had a problem. I can see the convenience of having a
tank mounted under your trailer but their are risks.
If I get a hole in one of my jerry cans I only lose the
water in that can. A few years ago an Exploroz member got into a bit of trouble when he holed his
water tank while travelling the Anne Beddel Highway. As it was the loss of
water forced him to cut short his trip and head for civilisation but it could have been a lot worse. Also, if I am doing a short trip then I need only take 1 or 2 cans and when I do day trips away from the camper it is easy to drop a jerry into the back of the car so I have ample
water for my day trip.
To get the
water from the jerry cans I use a super siphon. It holds the
water in the hose and all I have to do is drop the end below the
water level to re-commence the flow. They are also easy to refill even if I can't get the camper up to the
water supply.
Finally I don't have a problem with using the
water left in the jerrys when I get home to
water the garden. I screw the caps on only loosely so they can breathe in storage and have never had a problem with the
water tasting bad.
My 2c but it has been working for a long time.
Duncs
427410
Reply By: Member - Howard P (WA) - Tuesday, Aug 17, 2010 at 03:36
Hi Simon,
I have a 'Camel 65L'
water tank installed under my C/T, it has proven to be a very strong and reliable
tank. When it was new I had to clean & flush it out a few times to get rid of the plastic taste but after that all I do now when filling is add about half a cap of vanilla essence with the
water and all is good. From memory CAMEC on
Welshpool Rd sell them.
Camel web site - www.camelgroup.com.au
Hope this helps,
Howard
427418
Reply By: Member - Troll 81 (QLD) - Tuesday, Aug 17, 2010 at 08:38
I got a 80l
water bladder that's on the floor behind the drivers
seat and find it very good.
Always make sure you use food grade hoses otherwise you will get that garden hose taste.
427430
Reply By: Rangiephil - Tuesday, Aug 17, 2010 at 08:41
I notice that you do not want plastic taste.
If you are considering a stainless
tank be careful, as I have met several people with new
Camp'o'matics and
Kimberley Kampers where the stainless
tank has cracked adjacent to the welds as the
tank flexes and work hardens from the
water sloshing inside.
I have a 50 litre plastic
tank under my old 97
Camp'o'matic. these are a standard caravan fitment and only cost about $90 on line.
Mine wore through after 13 years of off road work, which I think is a great performance.
All in all I think the plastic tanks are the most practical.
For different shapes and sizes just look in on of the on line caravan parts sites. i used Caravans Plus in
Canberra,
Regards Philip A
427431
Reply By: Member - Oldbaz. NSW. - Tuesday, Aug 17, 2010 at 11:53
I go with Duncs above, I carry 20L plastic containers. 2 mounted on the side of the C/t & a couple of spares wherever. I leave home with fresh
tank water for
a decent cup of tea in one & only refill when empty. I see no use in lumping all
that weight around when washing & cooking
water is freely available in most
places. We carry sufficient
drinking water to suit the conditions. The number of posts re bad taste ,pump issues, & damage occurring to permanent tanks ensures
that I wont be tempted to go that way. I always know how much
water I have,
& can adjust the amount to suit the usage.......oldbaz
427450
Reply By: skmaint - Wednesday, Aug 18, 2010 at 12:22
Cheers for the info fellas....
No I wont be going for a stainless
tank as I have heard of them cracking also.
Putting a plastic or poly
tank under trailer just wasnt sure what was a good brand.....I will be carrying a couple of jerries of
water just as back up as I dont want to get caught with no
water at all, if something happens to the
tank.
There will usually be 4 of us on the trips so space is a big problem for me with the jerries.....i will just have to see how it works out with the way I want to go and take it from there.
Simon.
427579
