Wednesday, Aug 18, 2010 at 14:36
hi casdol
check to see if peizo ignitor is actually making a spark
if not check all connections and you may have to remove panels on outside of van and this will all enable you to check igniter if after checking for spark and there is'nt one
well then replace it/check that the inside gas tap is on
on old vans it's usually found in a cupboard under or near the fridge or under bench
seat near the fridge hand has to be inline with the pipe to be on
while outside at the fridge rear access hole
check the chimney and burner make sure there are no dead moths or spiders/webs etc around the burner jet etc give it a blast with air if availuble
if the vent panels have fly mesh on them make sure they are clean
wash them with truckwash and brush
blocked mesh will make a burner smoke and/or go outclean these regulary if travelling on dirt /dusty roads
and remove the baffle that hangs down in the chimney
on a wire to see if it is cleanbolw air up the pipe not down on the burner
if the gas bottles were'nt on the van at some stage prior to you purchasing which is quiet often the case they get used on bbq's etc
there could be
water or condensation in the gas pipes and this will have a big effect on trying to get ignition in fact it wont ignite at all with this problem but
but as mentioned try lighting all the gas stove burners before proceeding to this step in remedy
i might add if you are not competant to do any of this do not proceed to next step and get a gas man to do this
on an 80s van last year i had to undo all the pipe conections under the van and blow compressed air through them to get out
water and condensation for several minutes
if the regulator looks old it could
well be the problem as a lot of old vans 80's vintage still have the original regs and the diaghams fail
replace it with the new tpye regulator as the old type are longer legal it will void your insurance fit the new fail safe type
after refitting pipes including to the fridge burner check joints with soapy
water to make sure none are leaking
i did this useing low compressed air not gas with some fittings i had for connection to gas pipe at the front
then when thats done go to the stove and light all the burners first to get the air out and the gas through it may take a while only do one at a time large burner first
hoping this will be of help
but let me make it very clear
i take no responsibility for what ever you may attemp as i dont know what your capabilities are
427591
