Kulkyne Kampers Solar Panel Kits
Submitted: Thursday, Aug 19, 2010 at 13:28
ThreadID: 80811 Views:6785 Replies:10 FollowUps:15
Related Pages
Have been looking around for an 80 - 100 Watt portable solar panel kit. It is obvious the rush on fitting solar for domerstic use has pushed the price of panels up.
Have seen 80 Watt kits priced between $1200 to $1500 from a variety of suppliers in Sth QLD.
In an attempt to source something more reasonably priced I came across some from Kulkyne Kampers, located in Red Cliffs, which I believe is near Mildura. The 80 Watt kits are $770!
I would like to know if anyone on the forum has purchased their panel kits and any feedback on the kits as well as service by the supplier, be it good or bad.
Reply By: Gronk - Thursday, Aug 19, 2010 at 14:12
I purchased a 100W folding kit from Mandrake for approx $450....no probs so far with it...works fine..
Price maybe slightly higher now, but wouldn't be much I would think..
AnswerID: 427706
Reply By: cruza25 - Thursday, Aug 19, 2010 at 14:20
i got my 100w for 350 delivered from here
look good and output is whats expected
http://cgi.ebay.com.au/NEW-100W-Folding-Solar-Panel-12V-Camping-Caravan-Tent-/330460232718?pt=AU_Solar
a grade and mono with a juta controller
if you prefer a well known seller then mandrake seems highly recommended
i was just on a tight budget so got the ebay one
good luck
mike
AnswerID: 427708
Reply By: Rockape - Thursday, Aug 19, 2010 at 14:47
Try this one, he is a business member here and his prices and quality are good.
Link
AnswerID: 427711
Follow Up By: Wizard1 - Friday, Aug 20, 2010 at 11:26
The prices are unbelievable. Have you used the products?
FollowupID: 698478
Follow Up By: Rockape - Friday, Aug 20, 2010 at 11:36
No I haven't, but many members have with no negative comments
FollowupID: 698480
Follow Up By: Wizard1 - Friday, Aug 20, 2010 at 12:52
Thanks for the info. Had a look at the website, might give them a call.
FollowupID: 698482
Reply By: Member - Mary W NW VIC - Thursday, Aug 19, 2010 at 15:26
Hi Wizard,
I live in Red Cliffs and know Brett and his staff well.
Have purchased 100 watt kit and controller from them and it's been sitting on my roof rack supplying power to a agm battery which runs my Lunar 50litre fridge with ease for over 12 months and some pretty rough roads.
Also purchased the fridge,40litre water tank,Redarc smart battery regulater/charger from them.They also fitted the water tank and redarc for me.
Their service is excellent and they dispatch Australia wide and above all prices are reasonable,
Mary
"Some people walk in the rain,others just get wet."
AnswerID: 427715
Reply By: Mandrake's Solar Power- Thursday, Aug 19, 2010 at 15:44
Thanks fellahs - I'm still around -
"" It is obvious the rush on fitting solar for domerstic use has pushed the price of panels up. ""
Not true for the Kits - The demand for A1 quality solar cells has peaked and manufacturing runs have altered due to demand exceeding supply but so far ( touch wood ) the prices have not risen ...
My next shipment has been delayed 2 weeks for that reason ...
Steve
AnswerID: 427723
Reply By: WATTS2C - Thursday, Aug 19, 2010 at 16:12
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
AnswerID: 427732
Reply By: WATTS2C - Thursday, Aug 19, 2010 at 16:26
if anything, panels have come down in price. Recognised brands like the Kyocera 135W panel can be purchased for under $1000...
AnswerID: 427733
Follow Up By: Maîneÿ . . .- Thursday, Aug 19, 2010 at 17:40
The Kyocera 135W panel uses a Multi-crystalline cell, although of reasonably good efficiency, they are not as efficient as a Mono-crystalline cell of the same physical size.
Maîneÿ . . .
FollowupID: 698390
Follow Up By: WATTS2C - Friday, Aug 20, 2010 at 08:24
mmmmm... if you go to http://www.dkasolarcentre.com.au/ an independent site that provides live stats on various solar panels you will see that Kyocera is the most efficient panel on the market
FollowupID: 698465
Follow Up By: Maîneÿ . . .- Friday, Aug 20, 2010 at 14:33
Went as directed to the link shown, yes, Kyocera is high, but definately not the most efficient panel tested, the link I have placed shows this clearly.
Variation between Kyocera and Sunpower
Go to site and click on numbers '10' & '14' for direct comparison.
The Sunpower *Mono-crystalline* cell is clearly shown as the higher output panel (is colored light blue) and a hell of a lot less expensive than Kyocera.
Kyocera make a fantastic panel, but being Multi-crystalline they are not as efficient as a Mono-crystalline using same capacity cell.
It would be good if they tested the more common panels in the same way to give direct comparison for people to gauge the effectiveness of each cell or panel, then there would be no misleading sales information floating around.
Maîneÿ . . .
FollowupID: 698498
Follow Up By: WATTS2C - Friday, Aug 20, 2010 at 14:36
just followed the link and guess what - the Kyocera is out performing the Sunpower panel, not just today, but over the last week, the last month and last 12 mnths...
MH
FollowupID: 698499
Follow Up By: Sir Kev & Darkie - Friday, Aug 20, 2010 at 14:55
MH,
So what happened about in about May 2010 then??
Looks to my untrained eye that the Sunpower greatly out performed the Kyocera. But throughout the rest of it they were both reasonably close. Sometime the Kyocera was better but others the Sunpower was.
It would be good to have some unbiased opinions from people with knowledge on these types of things rather than smoke and mirrors (which is just like the current election campaign) to promote something that you selling.
Cheers Kev
Russell Coight:
FollowupID: 698504
Follow Up By: Maîneÿ . . .- Friday, Aug 20, 2010 at 15:04
so your saying the *link I placed* above shows the Kyocera to be out performing the Sunpower panel??
You say your link has the Dark Blue Kyocera line higher than the Light Blue SunPower Line??
No way , the Dark blue Kyocera line only appears higher 8 times in 12 months, maybe just a few %, the other 99% the Sunpower is giving higher output.
If you use *todays* graph it's blatantly obvious as to the higher output panel, because there are less major graphical changes made in a single day.
This will then form part of the history graph in the following months.
But I'm not going to get into an argument how a graph is read, you placed it here, I'm only using it to show the output variation, if the point can't be substantiated, then I would not have used your graph, I say let the readers make their own logical decision.
To clarify the graphical user interface, click between the Sunpower (10) and Kyocera (14) and the variations in output will become evident as they superimpose over each other at your command.
Note:
I'm not connected in any way, with either brand of solar panel shown :)
Maîneÿ . . .
FollowupID: 698506
Follow Up By: WATTS2C - Friday, Aug 20, 2010 at 15:11
I don't claim to be an expert, but using the link - which we recommend people do if they want to make an informed decision - and then using normalised output which gives you a true indication of output - you will see that the Kyocera outperforms the Sunpower panels.
I'm not saying that Sunpower aren't a good choice - because in all fairness they are a good panel. But the Kyocera is a little better. And that's why a large number of caravan/RV manufacturers and repairers prefere Kyocera.
FollowupID: 698507
Follow Up By: Maîneÿ . . .- Friday, Aug 20, 2010 at 15:17
Watts2C
Now more interesting *factual* information is available from the site
it actually states in 'words' the following relevant information.
"The average daily energy output of each panel is:
# the Kyocera is rated @ 27.59 Kwh
# the SunPower is rated @ 31.34 kwh"
End of the argument, and now lets get on with life
how you read the graph is obviously very one sided because you sell the Kyocera
Maîneÿ . . .
FollowupID: 698508
Follow Up By: WATTS2C - Friday, Aug 20, 2010 at 15:31
and the Kyocera panel is 135W compared to the Sunpower 215W...
FollowupID: 698510
Follow Up By: Maîneÿ . . .- Friday, Aug 20, 2010 at 15:57
the system sizes are as follows,
Kyocera system is: 5.5 Kw rated @ 13.8% efficiency
Sunpower system is: 5.8 Kw rated @ 17.3% efficiency
Now get out the calculator and you do the sums :)
Maîneÿ . . .
FollowupID: 698516
Reply By: Member - Greg H (NT) - Thursday, Aug 19, 2010 at 21:27
I bought the Primus 80w kit. It does my job.
Camper trailer, 100a battery, 2 fluro lights and fridge.
Tomorrow is here!
AnswerID: 427768
Follow Up By: Wizard1 - Friday, Aug 20, 2010 at 11:28
How much dod you pay for the kit?
FollowupID: 698479
Follow Up By: Member - Greg H (NT) - Friday, Aug 20, 2010 at 21:17
Wizard1
$995.00
Tomorrow is here!
FollowupID: 698583
Reply By: TrevorDavid- Friday, Aug 20, 2010 at 10:06
Wizard 1, I purchased a 120 watt bi-fold kit from them. Great product, Great service, and yes Red Cliffs is near Mildura
TDB
dontyajustluvit
AnswerID: 427821
Reply By: Member - Ed C (QLD) - Friday, Aug 20, 2010 at 12:18
If I was in the market for solar panels, one of the first places I'd look would be
this seller here
YMMV
Confucius say.....
AnswerID: 427838
