Distance between fuel stops.
Submitted: Thursday, Aug 19, 2010 at 20:08
Member - KC (TAS)
Evening all, does anyone know if there is a place on here where I can find out
the distances between
fuel stops between
Adelaide and
Darwin? ie, what would
be the longest distance between stops. (
fuel, that is.) Searching for a friend.
Thank you for your time.
kev.
Reply By: Cruiser .- Thursday, Aug 19, 2010 at 20:15
Reply By: Member - Marc Luther B (WA) - Thursday, Aug 19, 2010 at 20:29
Hi KC
If I remember my short time in
Adelaide, there are a lot of truck bases in Gepps Cross. The sites suggested are great, and for some first hand knowledge, check with the drivers that do the run "up the guts" as they put it.
Marc
427760
Follow Up By: Member - KC (TAS) - Thursday, Aug 19, 2010 at 20:36
Thank you all very much for that. That should cover it very
well...
698424
Reply By: willem269 - Friday, Aug 20, 2010 at 01:02
Hi Kev, I reckon everything is solved. The answer was: there are plenty
fuel stops. Like there are in the Nullarbor. But what we learnt from crossing the Nullarbor a couple of times, it's worth checking
fuel prices as they can differ quite a bit. So tell your friend that if he has a CB or
UHF radio, to call on the caravaners and/or campervaners channel and ask about prices. Not when the
fuel indicator is on the E of course ;-)
427790
Follow Up By: Member - KC (TAS) - Friday, Aug 20, 2010 at 10:07
G'Day Willem, long time no read. That is a very good idea, I will pass that on
to him. Thank you.
698469
Follow Up By: willem269 - Friday, Aug 20, 2010 at 16:22
Hi KC, must be a mix-up, I'm not the famous
well known Willem from
Peterborough. I'm a Dutchman called Willem from Wilsum Germany. Did go around the block (Oz) from 2001 till 2007 a couple of times. Now back in Europe but we will be back Down Under from mid October till the end of March for a new adventure. Cheers.
698526
Follow Up By: Member - KC (TAS) - Saturday, Aug 21, 2010 at 08:50
Sorry, my mistake. Good luck on your next adventure.
698609
