Friday, Aug 20, 2010 at 23:15
Hi Marc,
The firmware is the operating system of your camera, a bit like XP, Vista or Windows 7 is on your PC, or if you have a MAC, MAX OS.
Canon from time to time releases updates to the firmware to fix software bugs, improve performance or provide enhanced features.
There is a link off the Canon website to the site to download the latest firmware, or you can follow this link
Canon Firmware Website and select your camera from the list.
The instructions for updating the firmware will be shown when you follow the link, basically you format an SD Card in your camera (you should always format your cards 'in camera', Microsoft & Apple do not 'format' the way Canon does), then download the firmware file from Canon, expand it on your PC (run it & it self expands), & then you copy the file to the SD card, put the SD card in your camera, turn on the camera, go to the 'Menu' & 'Setup-up 3' and follow the prompts.
Vers. 1.0.8 appears to fix a bug with the movies function, whilst this might not be a particular problem you'll encounter, it is good practise to be running the latest firmware.
The Canon software is not very user friendly or workflow efficient, so you might like to look at using 3rd party software for editing / manipulating / cataloging your photos such as Adobe Lightroom V3 or Apple Aperture, especially if you take your photos in RAW & edit them. (if you intend to edit or print photos in large format then using the highest resolution your camera has, and preferably in RAW, will give you better results - the manual should explain this).
Don't forget to regularly backup your photos onto other media & store them offsite, PC hard disks do fail & PCs also get stolen, so a backup stored separately is desirable if the photos are important to you.
Jeff
698599
