battery charger/inverter combonation setup.
Submitted: Friday, Aug 20, 2010 at 11:29
Member - Matt K (NSW)
How do u setup inverter & ctec battery charger permantley in camper tralier & also in back of ute. Thanks.
Reply By: Honky - Friday, Aug 20, 2010 at 14:35
I fried an inverter when I used it at the same time as I was charging the battery with a 4 stage charger.
Honky
427850
Follow Up By: Maîneÿ . . .- Saturday, Aug 21, 2010 at 22:17
I use my inverter when charging the battery system without undue consequences, I believe it was coincidental it died simultaneously as battery was being charged.
Maîneÿ . . .
698673
Reply By: Maîneÿ . . .- Saturday, Aug 21, 2010 at 21:47
First thing I will say is they are two totally different items, doing two totally different things, so they are set-up independently.
The Inverter takes charge *from* the battery and should be direct-wired to the battery with a fuse at/near the (+) battery connection.
The inverter must be located in a suitable stable area with plenty of fresh cool air available for cooling and away from any possible chance of getting the ingress of moisture.
The battery charger will put charge *into* the battery and can be placed where required.
You actually say: "setup inverter & ctec battery charger *permantley* in camper tralier & ALSO in back of ute"
unless you have 2 of each - with great difficulty :-)
Maîneÿ . . .
427971
