Exporting places from Google Earth to GPS
Submitted: Saturday, Aug 21, 2010 at 19:25
ThreadID: 80862 Views:5097 Replies:4 FollowUps:16
Evening readers
I have spent a a bit of time over the last 3 months building up a collection of Places on Google Earth. I have mapped a lot of the High Country in NSW and Victoria and can waste plenty of time "driving" the tracks from my desk and dreaming of my next 4WD journey.
Image Could Not Be Found
Do any of you computer whizzes know if I can upload these places to my Magellan Xplorist?
Google Earth seems happy to import waypoints from the GPS, but can I send them the other way?
I'm not sure where on my computer the places are saved and what format they are in. (?.kml)
Reply By: The Explorer - Saturday, Aug 21, 2010 at 20:13
Oziexplorer may be your best path. Current version allows you to view GE directly, save waypoints and tracks and send data straight to your explorists gps. Demo version doesnt allow this so a few bucks involved.
AnswerID: 427963
Follow Up By: The Explorer - Saturday, Aug 21, 2010 at 20:27
Hi again...
Maybe try GBSBabel as first pass..
GPSBabel download page
Should have ability to convert kml to exploirst format.
FollowupID: 698661
Follow Up By: The Explorer - Saturday, Aug 21, 2010 at 20:50
By jingoes, I've lost my mind (been a while since I used a Magellan)
Try Magellans VantagePoint - does the job (import kml then export to eXplorist)
VantagePoint Download
FollowupID: 698662
Follow Up By: SteveL - Saturday, Aug 21, 2010 at 21:23
If you want to use Google Earth maps in Oziexplorer then a program called Googleozi does a brilliant job.
FollowupID: 698664
Follow Up By: The Explorer - Saturday, Aug 21, 2010 at 21:30
Mobile Atlas Creator is better
though we have gone off topic. You can view Google Earth in Oziexplorer anyway (if you have internet). Question relatated to exporting kml files to eXplorist Xl.
FollowupID: 698665
Follow Up By: Glenndini - Saturday, Aug 21, 2010 at 22:41
I can view google earth in oziexplorer? Would you mind pointing out where this is?
I've seen this "Now includes support for Google Earth within OziExplorer. There is a link to the OziExplorer Google Earth page (on the OziExplorer page) where the .map file can be downloaded." in the help file but never could figure out where this "oziexplorer page" is.
FollowupID: 698675
Follow Up By: The Explorer - Saturday, Aug 21, 2010 at 23:11
@Glenndini
Make sure you have the latest version of OziExplorer
Ozi webpage
..on the same page is the link to the required info on the use of "Internet Maps" within OziExplorer...here is direct link..
FollowupID: 698676
Follow Up By: The Explorer - Saturday, Aug 21, 2010 at 23:13
wooops wrong button...here it is :)
Internet Maps within OziExplorer
FollowupID: 698677
Follow Up By: Glenndini - Saturday, Aug 21, 2010 at 23:23
Thanks. I eventually found it. As with most things on that website you almost need a GPS to navigate around it.
FollowupID: 698678
Follow Up By: The Explorer - Sunday, Aug 22, 2010 at 00:03
Yes ..some websites are confusing.
FollowupID: 698680
Follow Up By: Member - Michael O (NSW) - Sunday, Aug 22, 2010 at 09:34
Thanks for your input Greg!
FollowupID: 698688
Reply By: Member - The Bushwhackers -NSW - Sunday, Aug 22, 2010 at 08:46
Hi Michael
As the resident guru has already mentioned, GE exports in .KML format, so to send places, waypoints etc to your gps, the file needs to be converted to .GPX
Babelfish is apparently a good file converter. Have a look at the following link for a very simple explanation and 'walk through' of how to do the job.
GE to GPS
Cheers, Dave
AnswerID: 427997
Follow Up By: Member - Michael O (NSW) - Sunday, Aug 22, 2010 at 09:33
Cheers Dave
Just what I need. You're a legend!
Michael O
FollowupID: 698686
Follow Up By: Member - The Bushwhackers -NSW - Sunday, Aug 22, 2010 at 10:00
OOPS !! Babelfish should read GPSBABEL, think I have read 'Hitch Hikers Guide to the Galaxy' one time too many! :))
Dave
FollowupID: 698691
Follow Up By: The Explorer - Sunday, Aug 22, 2010 at 10:25
...you can't use GPX files in an eXplorist XL so converting from kml to gpx still results in an unuseable file...but as mentioned GPSBABEL will convert into many formats including that required by the Explorist so we are still on the right path.
The Magellan VantagePoint program I mentioned actually has GPSBABEL incorporated into it so usng this may or may not be eassier than just straight GPSBABEL. I however, do not find VantagePoint very user friendly and a bit confusing to use, plus its slows my computer down a bit...but it does the job.
FollowupID: 698693
Reply By: Member - Doug T (NT) - Sunday, Aug 22, 2010 at 11:11
If you save all your required Google Earth KMZ files to a folder on the PC you can use this website to convert them to what ever you need, Garmin, Magellan etc. you will probably have to register on the website to use the conversion program.
POI Conversion
AnswerID: 428016
Follow Up By: The Explorer - Sunday, Aug 22, 2010 at 11:24
Doesnt appear to have any utilities to convert KML to Magellan eXplorist format though (or any Magellan format actually)...well not that I can see. Can you be more specific about which one you are talking about (with respect to original question that is)?...or is you suggestion just a generalised one?
FollowupID: 698695
Follow Up By: Member - Doug T (NT) - Sunday, Aug 22, 2010 at 12:04
Yeh, after I added the link I did check, your right, goes to show Garmin is the way to go.
FollowupID: 698699
Follow Up By: The Explorer - Sunday, Aug 22, 2010 at 12:39
Choice of a suitable GPS for any one person should include an assessment of a wide range of factors. Ability to create POIs using the website you posted maybe one thing to take into consideration but I dont think it holds much weight on its own. No doubt Garmin in general produce a good range of units that suit many peoples needs but they arent the best choice in all circumstances.
FollowupID: 698701
Reply By: Hairy (NT) - Monday, Aug 23, 2010 at 10:17
There was a really good explanation written by a member in thread 66253 in relation to Google and Oziexplorer.....might be worth a read.
AnswerID: 428109
