Coromal indepentant suspenion
Submitted: Sunday, Aug 22, 2010 at 18:09
ThreadID: 80876 Views:14263 Replies:7 FollowUps:4
Hello All
I am new to this caravan thing and just starting out.
I have bought a Coromal caravan with independent suspension and was wondering if it is possible to change it to springs and axle to lift it up so it doesn't drag on the driveway (driveway has a sloping edge near the gutter).
The back stays and stays bar holders drag when backing up the driveway.
Would anyone know where to take it to get change (Central Coast area ) or how much it would cost.
Thank you
Markcus
Reply By: Markcus - Sunday, Aug 22, 2010 at 18:13
Sorry forgot mention that its towed behind a 4wd wagon.
AnswerID: 428046
Reply By: Isuzumu - Sunday, Aug 22, 2010 at 19:14
You may be able to change the coils to air bags, make it easier to get more height. You may be able to put poly air bags in the original coils, not sure if the coils are big enough for the poly's. Any have a talk to people who make air bag inp susp. Mob in Brisbane called Vehicle Components might be worth a phone call.
AnswerID: 428051
Follow Up By: Member - Toyocrusa (NSW) - Sunday, Aug 22, 2010 at 19:23
Hi Bruce. Even though Coromal they say they are independant the ones I have seen have a leaf spring running between the two control arms similar to the "simplicity" setup so may not be possible. I wonder if the van sits level behind the 4wd or is high at the front. If it is level then the possibility of larger diameter wheels may help. Bob
FollowupID: 698737
Follow Up By: Isuzumu - Sunday, Aug 22, 2010 at 19:30
Hi Bob I am not sure of the suspension on the Coromal, if it had the leafs could you put on the bellow type air bags .... I am far from an expert on this....just looking to put air suspension on a new camper trailer we will be purchasing.
FollowupID: 698738
Reply By: Member - Graham H (QLD) - Sunday, Aug 22, 2010 at 19:44
What model Coromal is it.
I have a Princeton with "independant" suspension which is actually only two sets of axles with leaf springs as in two completely seperate sets.
Whilst is independant of each other it is no way the same as say a Jayco setup which has the springs connected via a swivel arm and thereby makes them "helper" springs.
Is your rig level when set up on the car or have you got the towball too high and the rear sags
Depending on how far you want to lift it you could alter the handling considerably by lifting it too far.
The cheapest way would be to get two heavy boards and pack the low area where you reverse in. Much less trouble than altering supension.
I had to get mine realigned and without a lot of work it cost Coromal $900.
AnswerID: 428057
Follow Up By: Markcus - Sunday, Aug 22, 2010 at 20:04
Hello
I have a 1989 coromal low line caravan with springs. I bought a drop down towing coupler before and im using it to tow box trailers around.
I found that it was the best thing that i bought.
I only need to lift the van by about 50mm so it doesn't scrap the driveway and leave marks.
Thanks for your comment
FollowupID: 698744
Reply By: Rockape - Sunday, Aug 22, 2010 at 19:51
Markus,
coromal suspension is excellent so I would hesitate changing it.
Gotta ask is the van level on the back of the wagon or do you need a dropped tow hitch.
Options you could employ are fit larger wheels/tyres when negotiating the driveway, place something down to take the slope out or modify the suspension.
To raise the suspension it would have to be engineered and could be done by removing the suspension and then installing a 50mm high sub frame with the original suspension mounted on that.
Have a good one
AnswerID: 428060
Follow Up By: Markcus - Sunday, Aug 22, 2010 at 20:11
Hello
I have a drop down hitch on the and its pretty level while towing.
I have been using this for towing trailers around and found it great..
I was thinking about the boards on the driveway (between the gutter and half way up the driveway).
It has 14" tyres and i dont know if i can change them.
Thank you for your comment....
FollowupID: 698746
Reply By: Ray - Monday, Aug 23, 2010 at 08:19
I had a Viscount Supreme some years ago and that had two small wheels under the back end to stop the caravan from bottoming out.
AnswerID: 428105
Reply By: disco driver - Monday, Aug 23, 2010 at 12:28
Markcus,
If your caravan is only giving you grief when you are backing up YOUR driveway and nowhere else, why bother changing it with suspension modifications.
Your problem could be solved by changing your drawbar tongue to one with another 50-75mm more drop just for backing up the driveway. Use your normal one for towing.
OK its a bit fiddly having to change it over each time you come in or out of the drive, BUT it does not change the caravan set up in any way either, which can be a good thing too.
IT's probably the cheapest and easiest option.
Hope this helps you solve your problem
Disco.
AnswerID: 428121
Reply By: Member - mazcan - Monday, Aug 23, 2010 at 13:12
hi markcus
is it at all possible to put in a culvet/pipe type drive way to permantly eliminate the drain problem
could be cheaper than altering the suspension
or have some steel cross overs made that can stay there for ever
that being subject to council rulings of course
AnswerID: 428124
