Metal Detectors
Submitted: Monday, Aug 23, 2010 at 15:03
ThreadID: 80891 Views:3379 Replies:6 FollowUps:3
It was suggested to me tha a MT would be ideal in finding lost lost water pipelines
around the farm. I then thought it may well be a source of entertainment & time
consumption as well. So my question is...what do you recomend for the casual
fossiker to buy ? I didnt envisage spending more than $400 bucks ...can I get
something more than a toy for that ? I appreciate it wont be a Minelab or similar.
Any thoughts on a Bounty Hunter Tracker Iv or the like ? All input very welcome,
including tips on how to use one.
cheers....oldbaz.
Reply By: Atta Boy Luther - Monday, Aug 23, 2010 at 16:08
With the best bounty hunter , dont expect to go much deeper than 200mm-250mm with a coke can sized object . 150mm for coins etc .
AnswerID: 428142
Reply By: Maîneÿ . . .- Monday, Aug 23, 2010 at 16:11
Ok, I watched two guys using a piece of bent wire to check for any existing water pipes for a subdivision, they were checking the notes of the guys who the previous day were using an electrical device of some sort to do the exact same thing.
I talked to the guys with the 'wire' thinking they were idiots, but to my amazement I was assured they were legit by a quick example, the guy was prepared to be blindfolded and still show me the same mark on the grass where the pipe was located, he did it time after time.
I was convinced, but still don't understand it :)
Maîneÿ . . .
AnswerID: 428143
Follow Up By: OldMike - Monday, Aug 23, 2010 at 17:15
Yep, sure does work. I can't help with the metal detector, but I can find underground water with a piece of bent wire. Can find underground pipes also, so long as they have water in them. Not everyone can do this and I have no idea how it works, but I do have a lot of trouble with static electricity.
I can also tell whether electricity is flowing through a wire eg. extension cord by holding my open hand in close proximity but not touching. Not sure if it is a blessing or a curse.
Mike
FollowupID: 698837
Follow Up By: Fred G NSW - Monday, Aug 23, 2010 at 17:16
Mainey, I've seen that done myself by a plumber mate. He used braising rods, and yep, it worked.
I'll watch this with interest Baz, as I'm wanting to get into gold fossicking.
Fred.
FollowupID: 698838
Follow Up By: D200Dug- Monday, Aug 23, 2010 at 19:14
The Australian skeptics society has a $100,000 prize for anyone who can do that under controlled conditions.
Some years ago they ran a competition with about 30 water diviners.
Not one of them got a result that was any better than guesswork :-) I have done this over a fault line on an opal mine and it did seem to work but I am convinced it is not possible to divine things by this method.
FollowupID: 698860
Reply By: howesy - Monday, Aug 23, 2010 at 17:04
I got one some years back from dick smith. It was cheap and had all the features of the expensive ones. Once you learnt to use it you could determine the size type of metal and depth if you were prepared to keep adjusting it. was awesome and the kids had great fun with it. Would be 10 years old now and still works great. Used it about a month ago to fine the sewr inspection for the neighbour after it had been buried for some years. Expensive is not always necessarily a requirement.
AnswerID: 428149
Reply By: Member - John S (INT) - Monday, Aug 23, 2010 at 17:12
G'day Oldbaz,
I have a gold snoop pro that i bought off ebay for a couple of hundred bucks, i have used it for finding water pipes that weren't down to far, finding fencing pliers dropped whilst fencing across a creek,because it has a waterproof coil, and have also found a few old coins around the house yard much to the kids enjoyment, a mate has the gold snoop pro as well as a couple of minelabs and he still uses it a fair bit finding coins,hope this helps .
Cheers John.
AnswerID: 428150
Reply By: Motherhen - Monday, Aug 23, 2010 at 17:56
Hi Oldbaz
Most of our water pipes are poly, so the bent wire (water divining) works best.
AnswerID: 428161
Reply By: olcoolone - Monday, Aug 23, 2010 at 18:23
If your only going to use it for finding pipes underground a cheap one will probably do.
We use Minelab detectors that once understood can detect items up to 1000mm deep if large enough and in the right soil.
Like most thing you pay for what you get even though the marketing hype from some cheaper brands will tell you different.
Garrett and White do some good priced detectors under the $600.00 price range.
Not all detectors work the same..... you can have someone use to a Garrett or White find stuff they will not find with a more expensive Minelab, but get someone who is use to a Minelab and the tables turn.
Detectors are like tyres, fridges, batteries and vehicles....every one thinks the brand they use is the best and the others are (not so good).
You will find people who use Minelab will stick to Minelab, people with White's will stick to White's and the same for Garrett uses.
The dearer you go the better the detector will be a depth and noise filtering, this can play a big part in the soil you detecting in.
Minelab, White and Garrett are the three I would recommend.
AnswerID: 428169
