Nissan patrol 3.0litre turbo diesel
Submitted: Monday, Aug 23, 2010 at 19:51
ThreadID: 80899 Views:3751 Replies:5 FollowUps:2
Hell everyone.
Ive bought a sept 2000 GU2 patrol at a auction for a cheap price it has a 3.0litre turbo diesel in it.
The engine was supose to be seized but when i pulled it apart i found the conrod journals were a bit melted but the crank shaft is in great.
im lookingat doing a full rebuild including pistons rings bearing the full kit.
Ive heard there was some problems with them. But with me replacing most of the internals and so forth am i likely to get rid of the old problems that these motors had.
What was it with the sump that needed to be modfied.?????????
How do i run this motor in as well when its all finished.?????
If i can get as much info as possible it would be great.
Reply By: Mr Z - Monday, Aug 23, 2010 at 19:56
just out of interest what sort of $$'s did you pick it up for, and how many k's?
I'd love to buy one fit a chev V8 diesel
AnswerID: 428185
Reply By: howesy - Monday, Aug 23, 2010 at 20:15
Short answer is no, plenty of these motors have been rebuilt professionally only to have them implode again, Some say its overboost caused my MAF and there are varying other theories.
Go here
http://users.on.net/~aschulze/ZD30/ZD30%20Y61%20Reference%20Document%20-%20Colour.pdf
There is a heap of info on the whole thing and also steps you can take to reduce the possibility of another failure. Enjoy your grenade.
AnswerID: 428189
Follow Up By: howesy - Monday, Aug 23, 2010 at 20:17
Copy and paste the whole link to get it to load. It is a PDF document.
FollowupID: 698866
Follow Up By: Member - Andrew (QLD) - Monday, Aug 23, 2010 at 20:25
Using the link at the bottom of the edit box:
-http://users.on.net/~aschulze/ZD30/ZD30%20Y61%20Reference%20Document%20-%20Colour.pdf
Andrew
FollowupID: 698868
Reply By: nickb - Monday, Aug 23, 2010 at 20:59
patrol4x4.com will have all your answers. Just be prepared to search and do lots of reading...
AnswerID: 428196
Reply By: Member - peter f (VIC) - Monday, Aug 23, 2010 at 21:14
reddeer
if I was you ,The first thing would be a exh gas temp gauge and a bigger
exhaust system , and drive it by temperature .
cheers mechpete .
AnswerID: 428198
Reply By: Hairy (NT) - Tuesday, Aug 24, 2010 at 15:41
Id get rid of the motor altogether.....they known as grenades for good reason.
AnswerID: 428283
