Wednesday, Aug 25, 2010 at 15:16
hl,
Maybe, your solar system is not operating at it's maximum rated performance ?
Maybe, you were camped in inclement weather conditions ?
Maybe, the regulator you use is not efficient ?
Yes, just too many "maybe's" and not enough answers.
Reasoning is 250 Watts (>14 amps) should give you enough amps to more than replace the current used by all the items you have listed.
I only use a 203 Watts solar system and run a fridge drawing 10 amps, which will be much more than you use, also with lights, computer and battery charging all done with an inverter, I've never seen the 200ah agm battery system showing below 12v (50%) in all the years it has been in use.
The way solar panels are rated is by their 'maximum' watts, most times these maximum watts are never seen by the regulator at all, and many lesser expensive panels are next to hopeless when used in low light conditions, this is what causes most of the real life, but avoidable lack of
solar power problems.
Maîneÿ . . .
699115
