Suburban Gas Hot Water not working
Submitted: Thursday, Aug 26, 2010 at 09:33
ThreadID: 80960 Views:11446 Replies:3 FollowUps:4
Good morning all from downtown Blackall Qld
In our Caravan we have a 3 year old Suburban Hot Water Storage Heater Model SW6DA and it has suddenly decided to stop working
We have checked the gas supply, all OK, checked the that the heater is trying to spark up and ignite gas.
The supplier says we shouldn't be having any problems at all with a unit this new. Has anyone had this happen and was there a simple solution?
PeteM Qld
Reply By: CLC50 (QLD ) - Thursday, Aug 26, 2010 at 09:46
Hi Peter
I had this problem once ,it was my water pump water was to low in tanks to pump
Your pump connection fuse could be damaged.
Hope this might help
AnswerID: 428487
Follow Up By: Member - Peter M (QLD) - Thursday, Aug 26, 2010 at 12:04
Thanks but I have just tried both mains pressure and water from tank via the pump which seems to be working very.
PeteM
FollowupID: 699195
Reply By: Gone Bush (WA) - Thursday, Aug 26, 2010 at 10:01
There is a reset button, it's the right hand one of two rubber "buttons" set into a rubber rectangle right in the middle of the HWS.
Have you tried that?
Googling "Suburban hot water troubleshooting" and "manuals" brings up a lot of useful info.
AnswerID: 428490
Follow Up By: Member - Peter M (QLD) - Thursday, Aug 26, 2010 at 12:08
The reset button does not seem to work
I have had a look at the fuses and wire connections and they seem OK
Sounds like I will have to order some parts from the supplier Coast to Coast I will start with a new circuit board which they say I can fit & if that doesn't work a new solenoid which a plumber has to fit.
Sounds expensive, but there doesn't seem to be anyone out in this country that can help
Many thanks anyway
PeteM
FollowupID: 699196
Follow Up By: paulnsw - Thursday, Aug 26, 2010 at 16:36
Guessing and ordering bits you are not sure is going to fix the problem will be expensive and painful. The ignition board and gas solenoid seldom give a problem. You can buy an ignition board for 20% price of Coast to Coast RV from the US.
You need to check if there is voltage getting to the ignition board and many other checks prior to buying bits. If you can find somebody there that knows what they are doing you can put in a temporary switch to open the gas solenoids and manually light the gas burner.
FollowupID: 699214
Follow Up By: paulnsw - Thursday, Aug 26, 2010 at 16:40
Ignition boards out of many other appliances will work if you can find a gas fitter or electrician that knows what they are doing. Ignition boards are generic interchangeable items. Many sell Dinosaur Electronics ignition boards. You could fit an ignition board from a Swift stove.
FollowupID: 699215
Reply By: jacknkaylene - Thursday, Aug 26, 2010 at 16:48
Hi there, have just had some issues myself with a suburban unit and found this document of great value.
Jack.
surburban manual
AnswerID: 428521
