Hissing/squealing Turbo Toyoto 100 series FTE
Submitted: Saturday, Aug 28, 2010 at 08:02
Member - Syd R (QLD)
I have developed an unusual high pitch squeal or hissing noise that increase with revs between 1800 and 2500 revs. The mechanics I used replace all the gaskets on the exhaust side but the squeal remains. I have tightened all the clamps on the Air cleaner and air input side. Any suggestion would be welcome
Reply By: 3GoBush - Saturday, Aug 28, 2010 at 08:05
I had an identical noise the other day, it was a leak at the inlet manifold.
We tightened the studs and no more noise.
428709
Reply By: Isuzumu - Saturday, Aug 28, 2010 at 09:09
While your at it check all the hoses and fittings to the turbo and intercooler
428713
Reply By: Dust-Devil - Saturday, Aug 28, 2010 at 10:39
Syd
Check the hoses after the turbo to the intercooler, and from the intercooler to the inlet manifold for splits in same.
I have a KJ JEEP that over the past 6 years has incurred a split in both of these hoses and the noises that it made covered all of the above that you describe and some.
DD
428729
Reply By: Member - DAZA (QLD) - Saturday, Aug 28, 2010 at 14:04
G/Day Syd
I recently had a problem with the EGR Valve Gaskets leaking on our Patrol, had the same symptoms as you are describing.
428743
Reply By: Member - Phil G (SA) - Saturday, Aug 28, 2010 at 15:11
The sprung flange from the dumppipe to exhaust can leak if the cat converter gets blocked with carbon. Had it happen to
mine - sound comes on at the same revs but was louder than what you are describing. Worth looking for signs of soot around this flange. The solution is to upgrade the exhaust to a 3" without a cat converter.
428754
Reply By: Mark R - Saturday, Aug 28, 2010 at 16:43
Recently had a similar problem with a whistle from about 2500rpm under load in our 100 TD. Thought it must be a leak but couldn't find it. I was a bit embarrassed when I took it to a mechanic who said "it's in the snorkel" then proceeded to take out the air filter to find a bloody great wasp nest in the bottom of the
snorkel. Cleaned it out, new filter and no noise!!
428764
