Tuesday, Aug 31, 2010 at 09:05
If you want to test just the battery with the fridge, why don't you just bypass all other wiring, run a short as possible cable direct to the fridge (ie a battery clip to cig' socket).
Then connect a voltmeter to the battery and monitor it while you plug the fridge in.
You should see the battery only drop by a few tenths of a volt, maybe 0.3 volts when the fridge starts, if there is a big drop, ie over 0.6 volts then that would indicate that it is probably time to get a new battery.
If there isn't a big drop in voltage when it starts, then leave it connected and see how long it runs for.
If you know how much power it uses per hour then times the amps per hour by how many hours it ran for and you get how many amps it has used before cutting out.
699710
