life span
Submitted: Tuesday, Aug 31, 2010 at 14:44
smokie
my deep cycle battery died it was 5 years old so just wondering what is the average life span of a deep cycle battery ?
Reply By: Ian & Sue - Tuesday, Aug 31, 2010 at 15:06
5 years sounds good to me - ours in not quite 12 months old and has just failed, ekkk... AC delco has a 12mth warranty but we are on the other side of Oz to the receipt.
429022
Follow Up By: MrBitchi (QLD) - Tuesday, Aug 31, 2010 at 15:08
I got just over 5 yrs from my Trojan.
699733
Follow Up By: Andrew & Jen - Tuesday, Aug 31, 2010 at 16:38
Hullo Ian and Sue
Do you know what your charge voltage was/is?
My understanding is that ACDelcos need higher voltages to charge properly.
Did you regulalry put them on a 240v charger?
I have 3 ACDelco house batteries on the boat and they have lasted 9 years and still OK.
Andrew
699744
Follow Up By: Member -Toonfish - Tuesday, Aug 31, 2010 at 21:45
have you tried a ac delco delco distributor and possibly find the receipt later as they are usually stamped or have someone fax a receipt to the store and or have one picked up somewhere closer .
699773
Reply By: roberttbruce - Tuesday, Aug 31, 2010 at 15:13
about half the time you've been gloating...lol.. I8)
5 years is fantastic... i've been averaging 12 months before a cold snap, corrugation, corrosion, oxidization, bad earth, overuse, regualtor fail, etc etc..
ruins them.....
but then, ive been out full time, in very harsh conditions...
429023
Reply By: Hairs & Fysh - Tuesday, Aug 31, 2010 at 15:53
Hi smokie,
I'd say 5 years is a good run,
I haven't owned the Cruise from new, only the last 6 years, The first battery, AFAIK lasted 8 years and the second one was not to far short of that either.
Where as I've replaced 2 in four years.
I use a Supercharge N70ZZL atm because they come with a 48 month warranty.
With all the pressures put on them these days, I'm surprised they have lasted as long as they have.
In a couple of months I will add a second under the bonnet.
429026
Reply By: bruce - Tuesday, Aug 31, 2010 at 16:09
A bit stiff..the battery in our van is 9 years old and still going strong ,had it tested about 6 mths ago ....and was told that it was in very good condition...maybe we are just lucky....cheers
429027
Follow Up By: skmaint - Tuesday, Aug 31, 2010 at 16:59
Nine years..cant complain about that....In the wet season we go through 2 batteries per genset onsite...13 gensets in total....heat kills them...But 5 years is a good run for a battery.
Well I would be happy if i got that out of my deep cycle...My 2c worth.
Simon.
699746
Reply By: Member - Keith P (NSW) - Tuesday, Aug 31, 2010 at 17:00
I regularly get around the 5 years (within a cuppla months either way) out of the batteries in my "other" car (a 1984 Peugeot 505 STI). I use almost exclusively Century old style batteries...ie...gotta service them regularly.
I have only had my current Patrol a cuppla years...so only time will tell with it.
Cheers Keith
429031
Reply By: Bushranger1 - Tuesday, Aug 31, 2010 at 17:13
5 years is pretty good. I assume you have a deep cycle battery as your second battery?
Batteries don't like.
1. Heat. (Thats why lots of new cars come with a shroud around the battery & draw air from outside the engine area)
2. Deep discharge. (Lead acid batteries last longer if you keep em topped up. Best if you don't go less than 50% discharge capacity)
4. Shaking around due to incorrect clamping down.
3. Voltage drop in the charge circuit.
When I lived on the road for 2 years I was amazed by the amount of dodgy installations I saw which were the cause of voltage drop. Even a drop of less than 1 volt from the 14.4 or so volt optimum charging voltage will significantly reduce the storage capacity.
Your installation sounds like it's ok
429033
Reply By: Member - Bucky - Tuesday, Aug 31, 2010 at 17:27
smokie
Mine died the day after we got back into Alice, after a big trip, and sometimes very corrugated roads, ie the Canning, the
Gibb River Road, the road into the Bungles, Wolfe
Creek Crater, and do not forget the Gunbarrell
15 months old ...
Bit of a shame that, but it really is the luck of the draw...
Some do last, some don't last, and brand name means nothing.
The one in the camper trailer has been in for 5 years, and covered every rough track I can chuck at it. Still going strong...
Go figure ?...........As I said the luck of the draw.
Bucky
429036
Reply By: Alloy c/t - Wednesday, Sep 01, 2010 at 09:23
Time for you to change to AGM style of batt , my first still going strong , bought Nov 2000 as aux batt underbonnett.
429091
Reply By: WATTS2C - Wednesday, Sep 01, 2010 at 09:37
5 years is about average for a deep cycle battery - although with tender loving care they can last longer.
we've never had any of the Fullriver's fail or come back to us.
MH
429093
