Sunday History Photo / Vic
Submitted: Sunday, Sep 05, 2010 at 07:11
ThreadID: 81140 Views:8016 Replies:7 FollowUps:4
The most distinctive product to carry the Furphy brand would certainly be the water cart. The presence of the cart in military camps in Australia during the First World War led to the name of Furphy becoming an indelible part of our language.
Image Could Not Be Found
The water cart was in itself a complete invention of John Furphy and was first made in the 1880's. At the time no similar article was used in Australia. Few houses of the time were designed to collect rain water from the roof and hence, water needed to be collected elsewhere and transported for stock and domestic use. The method of carting water was then confined to horse drawn drays or sleds with mounted wooden barrels or casks. At the same time the growing demand for agricultural implements, led to the establishment of a foundry with a furnace to cast components rather than the time consuming task of forging. This became the catalyst for the efficient production of the robust and mobile water carrier known then, and now, as the Furphy Farm Water Cart.
John Furphy was an experienced wheelwright and thus employed a similar method of construction for the water tank. It consisted of shrinking an iron band on the end casting to hold and tightly seal the cylinder or body of the tank, just as the iron tyre was fitted to the wooden body of the wagon wheel. The tanks were made of cast iron ends, 34 inches in diameter with a sheet steel body rolled to form a cylinder. For the first few years the cylinders were made from 1/8 inch black steel . All the sheet steel for the cart barrels was imported from England and Europe. Galvanized sheets were imported when they became available and when John Lysaght began galvanizing in Australia the body sheets were obtained from Melbourne. The first carts were available in 180 and 250 gallon capacities. The 180 gallon unit proved most popular because when filled, it weighed about a ton and was a fair load for a good horse. The tank was carefully balanced over the axle to distribute the weight for the horse whether the tank was empty or full.
The cart frame was made from wood and was fitted with 30 inch cast wheels. Rubber tyred wheels and a steel chassis were introduced in 1945, greatly improving the mobility of the cart. The first carts found a ready market in Victoria and the Riverina and eventually found their way into all states.
The tank itself remained fundamentally the same for the duration of its life. Production of the cast iron ends and other components ceased in 1983. It was then that an all new fabricated and hot dip galvanized tank was developed and continues to be in strong demand today. It has all the features of the original tank including size, profile and durability. However, the replacement of cast iron components with galvanized mild steel make the tank much lighter and more economical to produce.
Today, the tradition continues, when during the dry seasons, many old units are brought in for reconditioning. This simply involves the fitting of a new galvanized cylinder to the original cast ends using the same methods to those employed over 100 years ago.
John Furphy (1842-1920), engineering blacksmith, was born on 17 June 1842 at Kangaroo Ground, Victoria,
On 25 May 1866 at Kyneton John Furphy married Sarah Ann Vaughan; they had five sons and four daughters. Furphy lived in Shepparton until 1909 when he moved to Melbourne where he died on 23 September 1920. Descendants still operate the foundry.
Reply By: Member - Julie P (VIC) - Sunday, Sep 05, 2010 at 07:23
There is one outside the Riverside Caravan Park in Porepunkah (Vic) - very distinctive way to describe which park you are going to.
PS - hope it isn't flooded. They are on the Ovens river
AnswerID: 429388
Reply By: Member - Jack - Sunday, Sep 05, 2010 at 08:30
Terrific article Doug. Thanks.
It may further interest you to know that the peculiar inscription across the centre of the Water Cart at Ilfracombe is written in Pitman's Shorthand, and reads
"Water is a gift from God, but beer is a concoction of the Devil, don't drink beer"
This was added in 1920 by John Furphy's son, William, and was later changed to "Water is the gift of God, but beer and whisky are concoctions of the devil, come and have a drink of water" which has since become the more popular, recited version.
Not the sort of crowd you'd want to do a long trip with
Jack
AnswerID: 429390
Reply By: hiluxcab - Sunday, Sep 05, 2010 at 09:08
thanks for the sunday history always a good read
the furphy tank are a big collectable item the end are bring around $1500
complete tanks around $3000 the taps & lid are hard to find
AnswerID: 429392
Follow Up By: Member - Doug T (NT) - Sunday, Sep 05, 2010 at 09:14
Shhhhhh don't tell everyone that..next we'll read where some A/hole has nicked the one at Ilfracombe.
FollowupID: 700154
Reply By: Mr Pointyhead - Sunday, Sep 05, 2010 at 09:41
The Furphy company is still arround ( http://www.furphys.com.au/ ) and apparently they still teach their apprentices how to maintain the original water carts.
AnswerID: 429397
Follow Up By: Member - Doug T (NT) - Sunday, Sep 05, 2010 at 09:47
Didn't you read the last 5 words in the post.
but thanks for the link , good to see an Aussie business still going.
FollowupID: 700162
Follow Up By: ExplorOz Team - Kerry W (QLD) - Sunday, Sep 05, 2010 at 16:02
Doug I had to add a bit to your story if only to put some faces to the Furphy Watercart story.
Speaking of the Apprentices skills.. I used to work in Shepparton in my youth and 2 of my best friends Lou Tuckett and Col Watson did their apprenticeship at Furphys. "(Needless to say - I was occasionally around (in some ways assisting) the fixing of watercarts among other things for some of the local farmers.). I have to say that these guys were 2 of the cleverest guys I have met in my life simply because of what they could fix at a pinch. To literally do the impossible with nothing. (and with a smile and a wisecrack to boot).
They were widely skilled and had a great work ethic due to the huge diversity of the Furphy business.
Who can ignore Furphys great saying also embedded into each cart.
Good Better Best
Never let it rest
Til your good is better
and your Better Best.
There is a lot of History we can take for granted especially the innovations and ingenuity put into all aspects farming and engineering by small companies like Furphys and the people they trained over the years.
I attended Lou's 60th Birthday a year or so ago and thought Id post this pic from his party as also present was an Orchardist I worked for (John McDonald) who (along with his cousin Rod McDonald) invented the "lay flat" plastic tubing which was used by many farmers to irrigate from the irrigation channels in the Golburn Valley. The invention was claimed by ICI at the time I think, as John and his Cousin Rod got them to make the product for them but they didnt bother patenting the idea. (John is incidentally the son of Sir John McDonald - The Ex Premier of Victoria 1950-1952 and did a lot of the groundwork (literally) For the Irrigation schemes at the time). Lots on interesting stories I could not do justice on at the moment.
Below From Left to right John McDonald, Lou Tuckett, Col Watson - Me kneeling
Real Australian Characters - Needless to say Lou still restores old tanks this is one of his restorations - an old straight 8 Buick
Hope this just adds a little colour to your great story.
Kerry W (Qld)
-Helen Keller
FollowupID: 700193
Reply By: Fred G NSW - Sunday, Sep 05, 2010 at 10:29
Now that's what I call a real Furphy" Doug :-)
Good story mate.
Fred.
AnswerID: 429402
Reply By: The Explorer - Sunday, Sep 05, 2010 at 10:45
More info on same subject here
The Famous Furphy Water Cart
AnswerID: 429404
Reply By: OREJAP - Sunday, Sep 05, 2010 at 12:53
Good on Ya Doug, another great article with some good photos. Furphy's made an excellent camper trailer for awhile don't know if they are still doing so & their camp ovens are the best. Thanks again for another top article.
AnswerID: 429416
Follow Up By: hiluxcab - Sunday, Sep 05, 2010 at 19:33
there camp ovens are now made in china
FollowupID: 700215
