remove rust stains from paint, external rust.... oh great wise peoples
Submitted: Sunday, Sep 05, 2010 at 15:36
Joe Grace Doomadgee
Hi, i have rust stains on the roof that i want to remove, it is from "swarf" from holes drilled in a steel roof rack and are not just stains but "lumps" ....
It is on the outside of the paint not from the metal out ....
I have "looked" it up but all info is for rust stains that are just the discolouring not as surface crud like on
mine ...
I want to avoid sanding but if i have to i will, is there an acid that will move it and not the paint, i have even used a "green" scourer to no avail .....
Any ideas guys, gotta get it "flash" for our Mag Island n Yorky trip .... yes i confess i have not washed it for a long time, like 7 months :-<
Reply By: Member - Michael P (QLD) - Sunday, Sep 05, 2010 at 15:41
Joe
Try - PLUS "Rust Converter& Primer" www.plusrust.com
Mike
429429
Reply By: Member - Graham H (QLD) - Sunday, Sep 05, 2010 at 16:20
From bitter experience I have found the best way to fix it is clean it all off when you drill the holes.
Have used cutter to get
mine off or very fine 800 wet and dry paper
429435
Follow Up By: Joe Grace Doomadgee - Sunday, Sep 05, 2010 at 18:53
yes hind sight is wonderful .... long story but an inpending cyclone, need to fit some extra spotlights to the roof for a job we had to do and drilled holes, rain started while fitting lights, rushed job and never got the swarf from under the rack until it was to late ...
I did think that driving in heavy rain would have washed it away but not so eh...... oh
well
700208
Reply By: GQueue - Sunday, Sep 05, 2010 at 17:46
Worth a shot is whats called 'detailers clay'. Comes in a box set (Meguiars the most common, but there are others) with the clay and a lubricant. All directions are in the box, dead easy to use. Should be about $35-$40 from Ripco/Super Crap or Bursons etc....
Make sure you wash the car
well first, then hit the spots with the clay. This will hopefully get rid of the swarf particles. Then I'd hit it with a light cutting compound to remove any remaining stains/marks, something like Meguiars Scratch-X would be ideal (no, I don't work for Meguiars, they're just a reasonable product at a reasonable price that are also easy to get hold of). Again, follow the directions on the pack but both these should hopefully solve your problem for under $60 + an hour or so, and do no further damage to your paint.
In a perfect world, I'd also finally wax the area that has been clayed, but up to you and how much effort you want to put in.
Good luck.
429443
Reply By: Sir Kev & Darkie - Sunday, Sep 05, 2010 at 18:30
Joe,
Have a read of this LCOOL thread it has some great info about detailing.
Cheers Kev
| Russell Coight:
429445
Follow Up By: Joe Grace Doomadgee - Sunday, Sep 05, 2010 at 19:02
yes i did read that one, my problem is that the "swarf" has stuck to the paint and rusted and stained it, you can feel the lumps on the paint, the paint under it is fine so thats why i thought maybe i could use something like an acid to get the rusty bit off and then i can do the "detailing" bit ....
700210
Reply By: Member - Brian P (SA) - Sunday, Sep 05, 2010 at 20:24
Hi. On the boat I work on we use a product called MARINE CLEAN. It is an acid so be careful. Try it on a small area first where it can't be noticed if it leaves marks. It takes all the rust stains off. But be careful it is an ACID.
Best of luck. Brian
429461
Reply By: solo - Sunday, Sep 05, 2010 at 22:30
Hi Joe.
Yes Marine clean will treat the rust stains but you may need fine wet and dry paper to loosen the swarf. Careful to remove loosened swarf frequently.
Marine clean is usually phosphoric acid which converts iron oxide (rust) to iron phosphate which will inhibit futher corrosion. Phosphoric should be used carefully but is actually and ingredient of a famous cola drink ( thats why it cleans copper coins!) use diluted at least 1: 10 parts
water and rinse after. read the directions.
Cut and polish after.
Cheers SOLo
429482
Reply By: ozexplorer - Monday, Sep 06, 2010 at 11:16
Hi Joe
From a girls perspective I'm not sure if this will be of any help to you but a trick for removing rust stains on clothes, tiles etc, it to squeeze fresh lemon into the stain and cover with salt, allow to dry and then wash off, the rust is absorbed by the salt after the juice disolves it!
As I said just a girls perspective, may not apply to your needs.
Suellen
429515
Reply By: Member - dave e (QLD) - Monday, Sep 06, 2010 at 16:50
hi joe,i work on commercial boats and we use descale to wash decks and get rid of rust stains,it will eat small particles of metal,you can buy from marine shops,its good for steel ,alloy and fibreglass boats that have been painted,ive used it on the troopy to get rid of bad rust stains from my roof rack,,,,it is an acid so please follow instructions and youll have no dramas,it goes by many names,,rust rinse,descale,deckies mate,deck wash.
any probs just ask
dave
429536
