Roof Top tent help
Submitted: Monday, Sep 06, 2010 at 07:21
ThreadID: 81166 Views:6865 Replies:5 FollowUps:2
We have a roof top tent and have a few questions.
Our mattress tends to get damp and has condensation between the top of the floor and the underside of the mattress.(before anyone has a go, I don't have bladder issues. lol)
Also, we have the annexe that zips on to form a room under the extension and 1/2 the floor. Have found that when it's raining, that it leaks were the floor zips onto the sides. Water enters along the stitching.
Anyone else have these issues, and is there a way to fix them?
It is an ARB copy version.
Reply By: Member - Wim (Qld) - Monday, Sep 06, 2010 at 07:45
Esplanade
Had similar issues with ours.
Clark rubber have a black honeycomb material which we have put under the mattress. We stitched it to the mattress, now no problem.
A wax stick fixed the stitching problem.
regards
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 429498
Follow Up By: Michael ( Moss Vale NSW) - Monday, Sep 06, 2010 at 16:27
Wim!!! How thick is that honeycomb material?? And does it have a rubber smell? regards Michael
FollowupID: 700300
Reply By: Member - Carl- Monday, Sep 06, 2010 at 07:56
Under the mattress put a sheet of EVA or PE foam. Something like EVA 30 or PE 30. You can get it from clarke rubber of a camping shop. Crazy Clarkes have them as well. Those foam rubber ground mats. The EVA 30 is the best as it is the softest. The mattress in a Roof top is usually 40mm thick or 29-200 grade foam. This allows you body heat to pass through the mattress to the floor below. Silicone the mat to the wooden floor.
For the leaking water try "Thompsons water seal". In a 1 litre can from Bunnings. On a dry way wipe it on with a car sponge, leave it to dry for 30 minutes and do it again. Be generous in the amount.
AnswerID: 429499
Reply By: The Esplanade - Monday, Sep 06, 2010 at 08:52
Thanks very much for the tips.
Will try and get the foam this week. I guess this will also increase the comfort of the mattress as well? It is about 50mm or so thick. It is quite soft and dints if you press on an area. So the heat passing through onto the cooler aluminium floor makes sense
Andrew
AnswerID: 429503
Follow Up By: Member - Scott M (NSW) - Monday, Sep 06, 2010 at 12:11
I put a self inflater on top of my mattress and don't have any problems. My biggest issue is condensation on cold nights inside the tent...
FollowupID: 700273
Reply By: Member - Warren R- Karratha - Monday, Sep 06, 2010 at 15:41
G'day
We've just finished a trip to the centre with nights down to near zero and experienced the same thing most nights. I assume it's caused when the tent base temperature drops below dew point. The moisture was never to an extent where we felt it while sleeping and it did dry quickly. When I got home I taped some insulation material left over from the shed to the whole floor. It's like bubble wrap about 4mm thick with silver coating on one side and gold on the other. Haven't had time to test it yet, but I'm confident it will be ok.
By the way, it's our first trip with the Howling Moon, and we found it to be fantastic. No leaks in the rain or flapping in the wind. Weather was generally good so the annexe didn't even come out of the bag.
AnswerID: 429533
Reply By: Member - reggy 2 (VIC) - Monday, Sep 06, 2010 at 22:30
HI
We have had roof top for years the problem is it has to breath under the mattress I have a peice of trellis with shade cloth attached BINGO no more wet mattress (bunnings).
we left it loose in case it has to be removed hope this helps
cheers reggy2
AnswerID: 429578
